NEOCR 2.0 for 10G3 *Update NEOCR 2.1*
Originally posted by linh721990 View PostThe exact name is the Arnova 10b G3.
ok, not really sure whats going on with your tab ,but you can try this .
it's the very first rom neo put together , with the parameter file in place and loader also .
just put the nand fix on your sd card to flash after. and see if this works.
you putting everything in the rock dev folder then getting that error may be your problem .
any questions just ask ok .
hang on have to change the link . new link . just flash rom , cwm nand fix then download rotation fix and cwm that also you should be ok
Last edited by tattman65; 12-19-2012, 18:42.freaktab art developer if you like my work please buy me a pepsi
Bit confused
I have downloaded 2.1 with all fixes included.
I run RKAndroidTool.exe as admin but I get a black screen and then nothing.
Could somebody please let me know how to install this rom. I have previously used the SnakeKiller Rom Flash Tool and this has worked fine with the How To Guide.
Also is this for the 4GB and 8GB model?
Originally posted by axs446 View PostI have downloaded 2.1 with all fixes included.
look at my post above yours and try the rom kit i posted . all you have to do is flash nand fix and rotation fix afterwards . it's neo's first release of this rom . you just have to put the fixes in place .
some people seem to have some problems flashing this rom ,don't know why ?freaktab art developer if you like my work please buy me a pepsi
NEOCR 2.1 is no fonctionnal
Hello
I download the tarball for version CR2.1, which does not work for me, RKTool1.29 refuses to launch it, same for AFPTool.
I try to flash with the files contained in the folder rokdev and placing the parameter file, but does not work on my Arnova 10bG3 that the screen remains black.
By cons, if I flash the file that you give us in this topic tattman65 it works but not rotation.
I can provide you good files version 2.1 and fix the screen rotation if you like it?
I think the links are not good or correct view archives corromputs.
I accommodated if necessary.
Thank you in advance.
Thank you in advance.freaktab art developer if you like my work please buy me a pepsi
Originally posted by tattman65 View Postthanks man , i have all the correct files we have just been having some troubles with the download links . and when you use the flashtool you may need to have it run as administrator .
I have tried to execute things NeoCR2.1 archive of NeoMode as administrator, but it does not work, it does not lances, when the files that are included in the image directory parameter does not already running unlike the one you provided in your archive tattman65, more if I force entering the labor offsets with NeoMode files does not work in my tablet still black screen.
With your files tattman65 this works but I'm missing the file to fix screen rotation, I can not retrieve the position of NeoMode.
I feel that these are corromputs archive and non-functional, hence my proposal to the hosted server on one of my associations, to know who tried to fix the thing.
Is it possible to send me the files needed to be able to run 100% my tablet Arnova 10bG3 properly with NeoCR?
Re: NEOCR 2.0 for 10G3 *Update NEOCR 2.1*
I was checking the frequency my CPU is running with System Info. It said it was running 816mhz. It is capable of 1008mhz.
How can I change this with this ROM?
Arnova 10bG3Randy
Thanks. It worked.
Arnova 10bG3Randy
sorry ,i missed your post do you still want the files i don't think neo has had a chance to get the new download together yet ?freaktab art developer if you like my work please buy me a pepsi
Originally posted by neomode View Post
i tried this it does work .freaktab art developer if you like my work please buy me a pepsi
There are currently 2069 users online. 5 members and 2064 guests.
