NEOCR 2.0 for 10G3 *Update NEOCR 2.1*
    Originally posted by neomode View Post
    Please take a look there there is all you need -->
    Try to reflash it again and Erase IDB !
    Neomode
    I did this too.. Just doens't work o.o
      Thats is odd, tell me run you the RKFlash as Admin ?
      Can you use a different USB Cabel ?
      Neomode
        Neomode
        Yes, I do. I tried and failed
          ii tried this too. most download links have been broken for months. goto arctabletnews, they have a working stock rom with ext memory and market apps
          time to sell tab i think.
            No i dont think tho, i am Working on Android 4.2 for this Tab.
            Right now i am in Beta, if you want to try it tell me.
            Neomode
              Hi I'll give the beta a go. i havnt installed much to tht tablet because i know you been working on a new rom and was waiting. lol
              i though nobody was doing anything with this tab anymore
                Neomode
                I don't mind testing if u need some testers
                  New Version
                  The New Version is out check here
                  Neomode
                    Links still don't work to download jb 4.2.2
                      donloaded 2 times. rar broken
                      Update Tried to unzip with 7zip. works ok. don't work with winrar.
                      Installed the rom ok. seems to run nice. just no auto rotate at all. turned on/off still stuck in landscape
                        AW: NEOCR 2.0 for 10G3 *Update NEOCR 2.1*
                        Try to Download it and Work.
                        Deflate the Zip and Work.
                        May try a different Pack Utility like IZarc
                        Neomode
                        Send from my SG3
                          Neomode
                          Send from my SG3
                          Hi. I used 7zip and it worked a charm. just winrar couldnt open it.
                          cool rom. love the boot screen. seems stable at the mo. only problem so far, i got no screen rotate
                            ok so i took and flashed the old jb rotation fix we used on the last couple of roms and it works kinda sluggish but it does work . if you want to try it i'll post a link to a copy .
                            freaktab art developer if you like my work please buy me a pepsi
                              This Rotation Fix will not work. I must recompile it.
                              Neomode
                                can you post so i can try it. cheers.
                                great rom
