NEOCR 2.0 for 10G3 *Update NEOCR 2.1*
    AW: NEOCR 2.0 for 10G3 *Update NEOCR 2.1*
    thanks. can you run a benchmark pls?
    neomode
    Send from my SG3
      the benchmark i just ran was 2668 with nothing running .
      freaktab art developer if you like my work please buy me a pepsi
        not bad I think
        Thank you!
        Neomode
        Send from my SG3
          heres the jb sensor fix ,if ya'll want to give it a try . it works, just flash with cwm .
          it will allow for rotation ,just sometimes it seems to want to flip the screen when you did'nt move the tablet
            ok I just wondering that's work may this sensor files are newer than my :-(
            Send from my SG3
              so, i've been messing with this rom since last night , everything seems to be good so far .
              not really noticed any issues . the rotation thing is all i see so far. so thats great !
                That's great so I will integrate the fix you post in the Rom.
                Neomode
                Send from my SG3
                  https://www.dropbox.com/s/8a8e0j23u5...ix_MMA7660.zip
                  Hi. just installed this fix. it does rotate but orientation wrong.
                  i hold tablet portait and it flips to lanscape, turn tablet to landscape and it goes to portrait, so in effect, my screen is always 90 degrees out clockwise
                    mine did not do that just kinda lagged a bit when you flip the tablet . so,not real sure whats going on there.
                    maybe it done that cause you flashed it after flashing the rom , i flashed mine right when i flashed and done my factory reset and cleared cache and then applied the nand fix . then i flashed that before i used the tablet .
                      cool. i try that now. cheers
                      Update: tried what you did. same thing happened as before. rotation out 90 degrees. tried flashing in different orders but still the same.
                        well, dang ! i think neo is gonna try to do something about that. like i said it's just a bit slow on mine .
                        rotation stays where it should , just turns slow . so just maybe reflash and go without rotation . i'll talk to neo .
                          Cool. at the moment, ive flipped tablet and turned off rotate to lock it in portrait.
                            Please run the Program Hardware Info from Playstore and send me the Hardware Report to [email protected]. The same for Tattman65.
                            Thx
                            Neomode
                              Thx
                              Neomode
                              just sent my hardware info file.
                              thanks
                                that tablets at the house neo so when i get home i can do that for ya.
