MK808 Wifi Antenna fix! VIDEO to help you do it!
Originally posted by bdub951 View PostStrangely, with my antenna trimmed to 2.25 inches the performance is worse. I have it at a 90 degree angle from the board and I lost about 5db on signal strength and saw a decrease in performance. The longer antenna definitely provided the stronger signal.
If you want to make it better for sure you should buy one of those magnet antenna's that come with a coax. Cut the connector off and solder it to the pcb.... but there goes the smallness of the thing.
Btw you don't actually need to cut the antenna to size to experiment. This is HF we are talking about, so if you want to experiment with different sizes you can just fold the end part back next to the wire.
1 tiny little hole drilled in the case and a drop of hotglue over my DIY soldered antenna's connection then I fed the antenna through the hole and closed the case back up. The slightly thicker wire I used sticks out perfectly straight and looks very tolerable. It's all totally flexible too so it wont break.
I will update if things change.
Well to be honest wifi is a strange beast.
Now there is a saying 'measuring is knowing' but due to experience I have developed another one and that is 'know what you measure'
I have issues on the lower channels here which do not show up on inssider or wifi analyzer. When I got my spectrum analyzer I soon found out that some camera (I think) in the area is transmitting on these frequencies. If I check it on the analyzer the bursts are different and it is definately not a wifi type of modulation. This one is so strong that 10 meters (30ft) away from my Asus RT-N66U router I can't get a decent link. Now those things do not show up on the laptop nor the android monitoring tools.
Actually also the signal strenght is a strange beast. My wifes ZTE gives about 10dB better signal in the kitchen yet the download speed is way less than my Galaxy S2.
I hope to find a stick that operates on 5GHz since it doesn't reach that far, but far enough, and has alot more bandwidth available.
The real problem with the MK808 is the WiFi 0Ω divider (not a proper way to do a WiFi antenna divider).
The trace to the antenna in the back also goes through a via hole (bad for 2.4Ghz signals.."reflections").
In this case better one antenna than two:
I have done this mod on 5 different MK808-s and got at least a 10dB gain on each of them.
WiFi is rock solid at 65Mbps and signal strength is Excellent!
Thanks and good luck,
Lauri
P.S. I am not responsible, if you damage your device. Decent soldering skills required to remove the small 0402 size resistor shown on the picture.
Questions for lauriv
1) I could get 65Mbps connection and excellent signal when my MK808 is close to the Router without mod. So you need to tell us at what distance you perform test and what happens when you put 1 or 2 walls between the MK808 and the Access Point.
2)"In this case better one antenna than two". Does that mean the Antenna on the other side should be disconnected?
Originally posted by lauriv View PostThe real problem with the MK808 is the WiFi 0Ω divider (not a proper way to do a WiFi antenna divider).
[ATTACH=CONFIG]1265[/ATTACH]
Lauri
Lauri
Nice catch! Shows ... again ... that they don't even know what they are doing or designing. You cannot couple antennas like that.
It will probably explain a couple of symptoms that I have been reading.
Video link fixed.
Mine looks different inside and doesnt have the same antenna connections on both sides.
My unit looks different that the others I have seen posted and I thought I would post mine up. I have one heavily soldered antenna wire on one side and the other side has 2 pins that basically just touch the other antenna. check it out.
There are currently 2030 users online. 1 members and 2029 guests.
