Cube u30gth 1.11 900supersport 1.1 ROM
Notes
- Flashing will delete everything on your Cube consider backing up first and remve any sdcard
- Download and extract to a folder
- connect the tab to the PC (you did remove the sdcard)
- start the ROM flash tool
- put the tab into flash mode, the PC should detect it
- erase idb
- flash
- the tab should boot to recovery (this will take a few minutes)
- select reboot
- the tab should now boot
- first boot will probably complain about the nand simply select and format
So what do you get
- touch based clockwork recovery
- 2 gigs apps space
- init.d support
- root, debloat, market fixes, english by default
Finally thanks to the team here at freaktab
.gif)
