Cube U30GT H 1.11 900 supersport ROM
    All perfect. Thank you very much
      Build.prop
      Originally posted by BigbenNZ View Post
      Just a Query, I noticed that the build.prop seems to be unmodded Cube version.?
      All the others that I have seen, seem to use Samsung phone devices that use the Mali GPU..?
      The other day used Google Plays store via the Net, to check on a App, it list all my resent Devices, but most of these are listed as the Rooted ROMs that I have used in the pass, like Infected, Decontaminated , my last Modded build.prop was for a Samsang GT-N7000 is shows that but your latest
      Rom shows it as a U30GT, I have now modded your build.prop to gt-n7000 and it now list that.
      So it seems the Google Play store uses the Build.prop for compatible devices..?
      The reason I got this list as none of the devices were compatible.
      The app was
      BBC Sports App V1
        Finally find 900supersport produced the ROM. Thank you.
          USM Mass Storage Problems
          Originally posted by 900supersport View Post
          I use mostly Linux and occasionally windows vista. Never had any problems with either.
          Yes this is very problematic some times it 6 or more tries to get it to work, killing all tasks seem to help, Win 7 is a bit better but it will not let my copy files, locks up.
          Even then with both XP/W7 I often see that its unmounted the internal SD card and then changes the USB on the Cube back to turn on.
          The PC and the Cube show that the U30GT is USB connected and even the ADB driver when debugging is turned on.
          Often you have to leave it for Mins and some times it will connect.
          There is a very simple tool USBDeview that lets my see all the USB drivers and what the are connected to, and with a disable option for each.
            USB GPS on Cube U30GT-H
            Hi Supersport,
            Thank you for the wunderfull ROM it works fine.
            Allthough I want to install a ext. gps(based on PL2303) on usb but it not recognized.
            Is there any way to get this working?
            Appreciate a reaction from you.
            Thom
              Sorry I don't have any experience with GPS. Thanks for the positive comment on the ROM.
              900Supersport
              freaktab developer
                I decided to install Cube U30GT H 1.11 900 supersport ROM software, right now I have kasty-cube_u30gt_h-41-111-rooted2. I do, however, have doubts - after downloading the software archive and extracting, running Rom Flash Tool.exe, I see a screen with options.
                By default the setting 1 "Loader" is deselected, is it how it's supposed to be?
                Or should I select it?
                I installed the "kasty" software previously with Rockchip_Batch_Tool_v1.5.
                2.
                By default, I had the software in version 1.05, while starting up the tablet by holding Power+VolUp I had a recovery menu, right now on kasty-cube_u30gt_h-41-111-rooted2 this menu is absent. Can it have any impact on uploading new software in question 1.?
                No drivers are installed on the screenshot, the tablet has no problem entering FlashMode.
                  Re: Cube U30GT H 1.11 900 supersport ROM
                  No need to select loader, unless kasty has done something odd. Recovery should make no difference.
                  900Supersport
                  freaktab developer
                    So if I flash as described in the first post it will be all right?
                    Recovery should come back?
                    Can you write in a few words what it means the first option, which gives the loader selection, when to and when not to do?
                    Thanks in advance for your answers
                      Tablet connected to PC USB cable,
                      Power+VolDown,
                      Then Found RKAndroid Loader Rock USB
                      All ok?
                      Now I choose Erase NAND(IDB) and after this Flash ROM
                      All ok?
                        It is so cute that you worry this much
                          You know that my second time
                          Everything works great on the new ROM, there were no problems with updade.
                          Small error detected, go to:
                          Settings -> About tablet -> Additional system updates
                          "Unfortunately, Settings has stopped"
                            Hi guys,
                            First of thanks for the great ROM - been using yours for a while now (thats the end of my sucking up)
                            I have an issue with wifi after resuming from deep sleep - It does not reconnect, I have to turn the wifi off/on again to reconnect.
                            Chances are it is something I may have done/broke by installing stuff and trying to get bluetooth/GPS working (I cant remember if the issue was there in the vanilla 1.11 SS ROM?)
                            Thanks,
                            J.
                              For me wifi works perfectly.
                              Sometimes you have to switch off and switch on.
                              Bluetooth gps works well. (locus, google maps, kamap itp)
                              Pair tablet/gps.
                              Install this: https://play.google.com/store/apps/d....android.btgps
                                900supersport pls help me ! i have u30gt mini dont working gamers the gameloft
                                PLSS HELP ME
                                tested in u30gt cube mini-kasty cube_u30gt_mini-41-105-rooted
                                did not work, could you help me?
