Cube U30GT H 1.11 900 supersport ROM
Re: Cube U30GT H 1.11 900 supersport ROM
I've certainly not removed it.900Supersport
freaktab developer
Windows 8
does not seem to work with windows 8
(using windows 8 beta driver i downloaded from net which worked with http://www.arctablet.com/blog/forum/...ated-20121231/)
... just tried on xp computer and worked
thankyou CWM is great to haveLast edited by vinella; 07 February 2013, 00:42.
Look at /system/etc/permissions I add/edit four of these. If you open them you'll see them.900Supersport
freaktab developer
CWM Cashe Recovery Error
Thanks for you reply on the Corrupt SC Card thing
I stuffed up my other Rom not yours it ended up in a constant reboot,
so installed your Rom again when it gets to the CWM recover it leaves a few messages about Cache recovery problems.?
I just selected reboot, it still comes up with the corrupted SD Card thing but just did a format this time.
Is this OK to still use it..?
Yes once you have repaired/formatted the internal sdcard you should be good to go.900Supersport
freaktab developer
Sorry, on my commute to work so no access to the files.
I think it's
android.hardware.location.gps.xml
android.hardware.location.xml
com.android.location.provider.xml
tablet_core_hardware.xml
Try google Android market permission900Supersport
freaktab developer
Originally posted by 900supersport View PostSorry, on my commute to work so no access to the files.
I think it's
I got a new allwinner a31 tablet called NOVA 10, and I wanted to figure out how to get a full market on that, my test app that I currently cant see is tunein radio.
Can you guys see it on the cube?
Backup your current files and replace with mine. I think they should work fine.900Supersport
freaktab developer
It's ext4
To mount in a folder mntsystem try
sudo mount -t ext4 -o loop system.img mntsystem900Supersport
freaktab developer
tunein radio
Originally posted by Denis View PostOk cool, well I get how the market needs permissions etc, but what do these files do exactly, I cant simply copy and paste them to a different tablet can I>
Installed and Running.
****HELP!!!!!****
Have just flashed my friends U30GT-h with this rom and after the rom was flashed the tablet has just went BLACK and absolutely NO response.
I have tried to put it back into download mode to try and re-flash it but it will not do anything
If anyone can please help or point me in the right direction
Thanks a million
Martin
There are currently 1706 users online. 2 members and 1704 guests.
