TVLauncher 2.0
I just bought your app... awesome!! Just one questions, can we add all apps to a folder (in the new version) automatically? So if we install another app, it would go into "all apps" folder.
I wan't to set this launcher as default, but I need to be able to access all apps within the launcher.
Thanks!
Update: Sorry!! I just found out I can access all apps from the upper menu :-/
Hey guys.
New update in TVLauncher Beta is getting close. I've updated so that you don't scroll the banner to switch sections, but that you swipe the main screen. It's more intuitive.
In the meantime, please check out a game I made for schoolIt's called dungeon escape, and is made with Java. My group and I used about a week to accomplish this. It's not correctly balanced, but it works.
Here's the link if anyone wants to try it out: http://goo.gl/3XdiC
Source code can be found at: https://github.com/samyboy89/dungeonescape
Update - TVLauncher v. 2.73 - Beta
Change log is inside settings
Known bugs:
- Crash on orientation change
- Arrow key navigation is not yet optimized
- Screensaver top bar is half visible
Link: http://goo.gl/7UITw
Sam
When I updated, I first thought that banners were gone completely and freeked out a little lol. Glad they aren't.
Really like the new navigation style.
Still looking for an option to turn off the clock that's on the banner.
Also, hoping for an option to change background, because the black messes with the appearance of some tiles.
Other than those two things, everything seems great (as usual).
Edit: Attached images to show differences in background. Notices apps with black tiles, like XBMC, Youtube, & AirtightLast edited by vs604; 03 May 2013, 19:57.
Great, great Android Launcher!
Hello to all. Mr. "samyboy 89" you're application made me register to this forum.
I want to start this post, congratulating you for your excellent job on this application. You're a great Designer and Programmer. This launcher matches iOS/Apple's own quality on simplicity and beautifulness.
I have one question and a suggestion:
The question - I have the luck of living in a rural area. The problem is the internet. It is not reliable! Sometimes it works, sometimes it don't or works bad. If Ibuy you're application and somehow, the internet goes down, will it revert to demo mode? Can't you made a demo app and a buy app that doesn't need internet always on? I wouldn't mind to pay more, for the Pro version without internet connection dependency!
The suggestion - The launcher as a clock, all what I need! So, I close the down system menu. The problem is, when I need to make the system sleep/reboot/shutdown, I need to unhide the system menu to do that! Can you add an item to the top drop down menu, so we can access the system power options?
# I have another problem. When I place you're launcher as default, when starting, it doesn’t show the pictures. Is it because it's the demo mode?
* Testing on an Android mini pc box (Minix NEO X5)
Best regards to all,
FerreiraLast edited by f_ferreira; 04 May 2013, 12:55.
UPDATE - TVLauncher v. 2.75 - Beta
This is a nice update
Change log - inside settings
Link: http://goo.gl/StpPg
Sam
@f_ferreira: I will reply to you tomorrow
@f_ferreira
1. With the beta, TVLauncher is not much better at recognizing your purchase when not on the internet. I've build an extensive logic that makes sure you'll have the license whenever purchased.
2. I can add a button to the system power.
3. Well, I'm trying to fix this atm. It has to do with the SD card not being fully mounted on boot. I'll fix this soon. One of my main priorities.
@vs604
I will look into it. Thanks for mentioning!
Sam
Originally posted by vs604 View PostWith the latest update (2.75), the top menu bar (the grey one with all the settings options and stuff) doesn't completely go away in banner mode. Also, when switching between sections, the bar drops back down, when it's not supposed to.
In the previous versions, there were no such problems even when I hid the status bar.
Char encoding for RSS ticker
Hi folks,
This is my first appearance on this forum and I'd like to tell you that I really loved TV Launcher and I salute the developer and all contributors for making this product so promising.
Now a very unimportant problem I faced: I'm using a RSS source (http://feeds.folha.uol.com.br/folhinha/rss091.xml) that uses ISO-8859-1 as char encoding. I guess TV Launcher is not able to deal with this format, since I'm seeing "?" characters on places where there were special characters like "ç" and "á", very common in portuguese (my native language).
Thanks and congratulations!
Arnaldo
Arrow keying with wireless keyoboard doesn¨t work
Hi!
Thank´s for a great app that just keeps getting better. Installed the 2.75 beta last night and it runs well on my mk808 with Finless 1.7c rom.
Got one issue though: it doesn´t work to navigate through tiles with my Deltaco wireless keyboard. What I mean is that I dont get the marker that jumps between tiles to select them when I use the physical arrow keys on the keyboard. This worked fine on the version that´s in Google Play store (2.08 i think).
It works using the touch pad on the keyboard. And if i press up key a couple of times I will get up into the grey menu area where I can toggle between choices. It´s the main tile area that won't work.
Hope you can look into this.
There are currently 5400 users online. 4 members and 5396 guests.
