TVLauncher 2.0
Thanks tatubias, I've fixed it now.
Update 2.38 - Beta
- Better spacing between tiles
- New colors/look around the app
- MANY fixes, that should help with stability
- Drag and Drop more polished
Link: http://goo.gl/yCu9U
Sam
With the latest update (2.38.beta), I think the custom tiles function might be broken again. I do all the steps I explained earlier, and it says the tile was added. But, when I go to look, there's a blank, white tile where my custom tile should be. Tried this for two custom tiles for two different apps and same white tile for both.
Also, I know it should install as an update, so I shouldn't have to redo my spaces and stuff after I install a newer version. But when I click install apk, it says it couldn't be installed because the same app is already installed but with a different signature.
Originally posted by vs604 View PostWith the latest update (2.38.beta), I think the custom tiles function might be broken again. I do all the steps I explained earlier, and it says the tile was added. But, when I go to look, there's a blank, white tile where my custom tile should be. Tried this for two custom tiles for two different apps and same white tile for both.
About the different signatures, does it only happen with the latest version or do you mean from the one on the play store? Because of you mean the later, I've done it on purpose , just now for the beta. But when on play store it will have the same signature.
Sam
Update - TVLauncher 2.39 - Beta
- Fixed custom tiles (again)
- Some other small bugs fixed
- Reverted signature
Link: http://goo.gl/nf4xi
Sam
SamLast edited by vs604; 10 April 2013, 17:09.
Update - TVLauncher 2.50 Beta
- Changelog is inside of the application settings.
Link: http://goo.gl/kwxSC
Sam
Sam
1) What is "Custom bookmark form validation"
2) The wallpaper has been removed, but I really liked the dark blue one that was there earlier. What's the "New Feature" that's coming soon?
Thanks again for the great launcher man.
Re: TVLauncher 2.0
Okay, about the new feature I was talking about. I'm in the works of creating a screensaver for the app. When you are idle (you can choose the idle time) the app starts the screensaver. (Can also be triggered by a button) You can choose multiple wallpapers the the screensaver cycles through. You can also just use your system wallpaper or live wallpaper if desired.
It think this is much better than seeing just glimpses of the wallpaper throughout the app and in between tiles.
Sent from my Nexus 4 using Tapatalk 2
Sammy, when should we expect to see the direction key input fixed.
As it stands right now, this launcher is not viable for simple navigation input, ie kind of the point of the launcher to begin with.
Im just busting your balls, I know this is a beta, just wondering on a general timeframe for this.
If I could make a suggestion for the sections idea.
Instead of the dropdown list you have currently. It might make more sense from a UI/UX standpoint to have the section title in the top middle. When the user highlights the section an arrow shows up on the left, right or both sides of the section. They would be able to scroll left or right to assess the other sections.
Like this -
Accessing the side menus would not change so long as they were currently highlighting one of the app tiles on the screen.Last edited by Ritalin; 12 April 2013, 22:21.
There are currently 5454 users online. 3 members and 5451 guests.
