Enviado desde mi GT-I9000 usando Tapatalk 4 Beta
TVLauncher 2.0
Head over to http://www.freaktab.com/showthread.p...a-TV-Launcher-) to help me in further development, and to make TVLauncher fit your needs.
Thanks, Sam.
Originally posted by samyboy89 View PostHead over to http://www.freaktab.com/showthread.p...a-TV-Launcher-) to help me in further development, and to make TVLauncher fit your needs.
Thanks, Sam.
Samy,
Been following this development since your early builds. Awesome Launcher, especially your recent updates. You've literally fixed almost all my complaints. Here is some recommendations, some of which i know you are already working on.
- marquee selection around tiles when dpad is used EDIT: i see you have one, but i couldn't see it because of my black live wallpaper. maybe offer to change the marquee's color
-category transition options(i love the cube effect you have now, but maybe also offer basic transitions)
-transparency settings for app drawer
-maybe the ability to access the app drawer from somewhere other than the top menu
-ability to remove the "rss bar" from the bottom
-the top hidden menu is really nice, but it interferes with the categories right underneath them, maybe move that main settings menu somewhere other than directly on top of the categories
-widget support with the ability to scale and overlap widgets similarly to how ADW, ect. implement
-icon pack support similar to ADW/GO/Holo(there are some tasty icon packs out there nowadays)
EDIT: I also noticed there's a bug somewhere that my tiles keep changing to smaller res versions, and to fix it i force-close the launcher and restart it, and everything is fine.
here are some tiles i whipped up today, they are still formatted for the tile size on your older launcher as i didn't realize the resolution change until i finished them and put them on my tv. I will resize them all tomorrow and resave over the dropbox links. These look good with a darker background, I recommend Audio Glow Live Wallpaper
Move Beta Releases to the Market.
The entire method of releasing beta updates here on this site, needs to change. Its completely ineffective.
I tried to reach out to the Dev who once upon a time was much more responsive, through email and never did get a reply.
Here is the email and what I suggest be done with beta releases for this app.
I have been following your launcher since the first version you abandoned.
I have tried most of the builds you have put up, but to be honest checking that site for dropbox links is kind of getting old. Not to mention that its much harder to keep up with other peoples bug reports.
I am a beta member for the Zooper Widget app on android. This is how you handle beta releases!
My suggestion is to setup a Private Google Community page. When a member is accepted, there is a link that invites the user to participate in your beta builds of the app.
Once the user accepts the beta invite the Google Market then updates the user with whatever the latest build is that you have marked as a beta.
This is not only a much cleaner method of handling beta releases, but it also keeps your app from floating around in a free state on dropbox.
As a bonus you also get a community page where you can setup different sections, such as bug reports, icon submissions, ect...
If you would like any help in getting this setup, please feel free to contact me back.
Thanks for the great launcher
Ok, so i searched high and low for a good TV Launcher, found this and its everything i wanted (yay!)
however... since the version on google play is a bit bugged (you need to choose it everytime you restart) i came here for an update. Only to find that the updates has not been in its favor (in my very humble opinion) and i immediately uninstalled it and reverted back to the google play version.
What i love about the google play version (and the reason i payed for it) is that its so simple and minimalistic, no categories, no toolbars, nothing, just a bunch of tiles and 2 quick menus.. AWESOME!
Soooo, my question is: is there a version that is just like the google play version (2.0.8 i think?) that has the default launcher fix? the only version i can find and download in this thread is the latest one, all other links are brokenI registered only for this so if you can help in any way i would be very happy
until then i guess i have to live with the bugs :/
There are currently 2904 users online. 1 members and 2903 guests.
