That should work. You will find a different flash tool in the zip, use that.
Updated - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05
Re: Updated - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05
That should work. You will find a different flash tool in the zip, use that.900Supersport
freaktab developer
Originally posted by 900supersport View PostChecking 51cube.net I see a firmware dated 1 Feb 2013. I'll see if I can get a download and work up a ROM kit.
Sent from my U30GT 2 using Tapatalk 2
I noticed this while watching movie the otherday
I means the right speaker become left and left become right
RE: U30GT MS TOUCH SCREEN PROBLEM
Originally posted by elwaskop View PostHi friend, i download this kit oficial, but this is chine, i not understand this, you can help me?
THANKS
for the MS see http://www.freaktab.com/showthread.p...supersport-ROM900Supersport
freaktab developer
Sorry I've passed my mini onto my daughter so cannot check.900Supersport
freaktab developer
screen scratches badly
Love this tablet and this rom, I ordered 4000mah battery for it now. However, there are 2 things that bug me. Auto brightness doesn't work, although it has sensor. And the screen is AWFULLY bad, i simply touch it, without any force or anything and it scratches immediately. It's so soft.. I purhaced screen protectors, they are much more resistant than the screen.. Everytouch leaves mark on it
Always used a screen protector on mine. It's new owner is as pleased with it as I was :-)900Supersport
freaktab developer
Originally posted by xanpepe View PostExcuse me if this post don´t must be in this thread
WARNING ONLY TO Cube U30GT Mini 2013 model with FW DIM V1.02 20130122
Hi again. solution to camera missing
I extract a security copy with CMW from other mini cube U30GT with the same FW DIM V1.02 20130122, then I put the backup in my tablet and I restore with CMW and now all OK.
steps:
1-Download this file, is backup from cmw and aplication to flash cmw 6.0.2.7 MID v1.02 20130122.rar
2- install CMW 6.0.2.7 in the two tablets and do backup in the stock table.
3- copy in root of external sdcard complete clockworkmod folder.
4_ restore from sd external card
In archive add it is cmw backup and cmw 6.0.2.7
To install cmw, turn on your tablet when the system is on put usb conection with PC, now ejecute RKAndroidTool.exe, it is in cwm_base folder, you can to read below Found RKAndroid Mass Storage Usb, now click in reboot to flash mod, the tablet turn off automatic then and you can to read in RKAndroidtool window, Found RKAndroid Loader Rock Usb, now click in flash rom. OK.
CMW modo, without usb conection, and without power conection, hold first vol+ and second power for 4 to 5 seconds then release first power key then volume key
in cmw up down with volume +- keys, select option with power
select backup restore from external sdcard
when the restore done go back and reboot system now
it is all
now you have this:
[ATTACH=CONFIG]1889[/ATTACH]
@900supersport here it is the stock image but im cmw format, I can not find original fw DIM V1.02 20130122 in three days that I was searching.
in ref. to that post i will just kindly ask you if there is a custom rom avail. I got one of this clone mini here and the MID v1.02 FW is really not stable.
Thanks in advance.
If there is a more up to date stock firmware you can give me a link to I'll happily work it for you.900Supersport
freaktab developer
Originally posted by 900supersport View PostIf there is a more up to date stock firmware you can give me a link to I'll happily work it for you.
I flashed your FW MINI_v1.05_20121214 and after flashing the system booted and i saw on the home screen all icons including the camera icon. Buttons are working but the touch won´t work. The locking screen comes into fiew and thats it.
Is it possible to implant the touch funktion from the old MID FW into your rom?
Sorry, i don´t have no clue about cooking a ROM.
CU
Mebus
There are two versions the mini and mini s. Each requires it's own firmware.900Supersport
freaktab developer
Originally posted by 900supersport View PostThere are two versions the mini and mini s. Each requires it's own firmware.
thats the problem to find out. I tried to flash it with both (Mini and Mini S) ROM´s but both wont work. Only the actual ROM works. Please check on page 6 threat 101 for details. Its the same issue. With your 1.5 ROM seems that only the touch did´t work.
BR
Mebus
There are currently 1788 users online. 0 members and 1788 guests.
