Updated - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05
    Originally posted by 900supersport View Post
    Take it you where just stuck in a recovery loop?
    Yes. I'm stucked at recovery loop.
      Re: Updated - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05
      When did you get your mini?
      Last thing to try if I've included a boot loader within the latest ROM kit then from the romkit check boot loader, click the small square next to boot loader and select the included boot loader from the 900supersportROM folder, erase IDB, clear the check against boot loaders and flash (parameter, misc, kernel,recovery, boot and system.
      After that I think it will be stock ROM and build up.
      900Supersport
      freaktab developer
        I just got mine a week ago. So it's pretty new. It came with 1.04 stock rom but I upgraded to 1.05 kasty rooted rom. Now i'm trying yours cause of CWM.
        Tried your instruction. Went back to CWM again. So here's what I did in the romkit:
        1. Checked '1 (Loader)' and selected path to 900SupersportROM\bootloader.bin
        2. Erase IDB
        3. Unchecked '1 (Loader)'
        4. Flash ROM
        I left the rest of options to default which is checked for (2-7).
          Two things, is this the first time you flashed boot loader?
          Still in recovery loop.
          I'll be sorting the stock images shortly.
          900Supersport
          freaktab developer
            I've tried flashing it before after it doesn't work. But the effects are still the same.
            And yes still in recovery loop. I always do a reboot after reaching CWM.
              Here's the stock ROM, this is as available from Cube
              http://www.freak-tab.de/900superspor...121214.img.zip
              Please try this as a start.
              I'll soon have this as ROM kit
              900Supersport
              freaktab developer
                I've an error accessing it:
                Forbidden
                You don't have permission to access /900supersport/cube/U30MINI-4.1-V1.05_20121214.img.zip on this server.
                  I'm locked out too. i'll see if I can get neomode to resolve this.
                  900Supersport
                  freaktab developer
                    I'm uploading the files from the stock image, will be about an hour
                    Sent from my ARCHOS 80 COBALT using Tapatalk HD
                    900Supersport
                    freaktab developer
                      I've tried stock image. Works well. Unless your stock image is different than the one from cube.
                        That's good, did it have the Chinese keyboard rather than the stock android keyboard?
                        It would be good to start the following with the stock Cube 1.05 firmware
                        My plan is we try the following using my flash tool progressing each time we suceed. All flashing by my Flash Tool
                        1. flash the stock ROM
                        2. add my parameter file
                        3. add my kernel and recovery
                        4. add my boot
                        5. add my system
                        Once again thanks for helping with this.
                        900Supersport
                        freaktab developer
                          4. add my boot
                          5. add my system
                          yes it has chinese keyboard. so how do we start flashing stock rom using your tool?
                            Stock Files Download==>http://www.freak-tab.de/900supersport/cube/stock.zip
                            instructions
                            • Download and unzip copy the stock folder and its contents into the 900supersportROM folder in my ROM kit
                            • create a 900ss folder in the 900supersportROM folder and move the current files from the 900supersportROM into the 900ss folder
                            • erase idb and do a full flash of the Stock ROM
                            • Copy the parameter file from the 900ss folder to the 900supersportROM folder erase idb and do a full flash of the the ROM
                            • add my kernel and recovery and flash just kernel and recovery
                            • erase idb and do a full flash of the the ROM
                            • add my boot and flash just boot
                            • add my system and flash just system
                            after each flash we are looking to boot through to android
                            I'm away now for an hour or two but will check in again ASAP
                            900Supersport
                            freaktab developer
                              instructions
                              Ok. Looks like the recovery loop starts happening at point 6 (erase idb and do a full flash of the the ROM). From then onwards the CWM loop never goes away.
                                More update on this. If I skip point 6. And proceed on flashing system and boot, the system goes straight into android OS. I can then get into CWM by shut down, then holding down power button + volume up (without USB cable connected of course). However, once in the CWM, it still have problem mounting sdcard and every other partition. I can reboot from CWM and it goes back to android OS without a CWM loop. All this happens if I skip point 6.
                                But why is it that CWM failed to mount partition in the first place?
