Hopefully I can make a video of it, in the event it still bugs.
Updated - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05
hi:
I need some help , look I try to fash the tablet but I cant,
when I try tu put erase idb the program shows me a error:maskroom must choose loader for erasing.
whe I try reboot to flashmode , again , device cant do a flash mode, because its not msc device.
and if I try flah mode, again error maskrom device must choose loader for upgrading.
please I need help I dont know what can i do , thank in advance
Sorry missed this. It sounds as though you have not managed to flash. I would suggest putting the tab back into flash mode and then checking boot loader, eraseidb and then flash.900Supersport
freaktab developer
Originally posted by CRISGAECAR View Postfinally i flash my device but know after the restart the screen only shows a screensaver with thelogo of freaktab.com and a 900 supersport rom v 1,1 , , I cant do nothing with the tab , please help if somebody knows thanks.
Only install CWM recovery, it is in a folder of MID v1.02 20130122.rar
Remember only install CWM read instructions in the link´s post
Try after installed to start tablet
Originally posted by Gravis View PostI have problem with battery.
I have like 50% of battery and then tablet getting off... how to calibrate battery?
Mine will shut off at 45%
I'm thinking about reverting back to 1.04 fw
Originally posted by a29psx View PostYeah, I also encounter screen backlight flickering before the battery runs out
After you flash it back, please write if this fix the problem with battery.
I've tried to fix problem with some applications and in CWM, without success...
Re: Updated - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05
I don't think it's firmware dependant. I use 1.05 on my mini with no issues over battery.900Supersport
freaktab developer
Originally posted by 900supersport View PostI don't think it's firmware dependant. I use 1.05 on my mini with no issues over battery.
the quality may be vary since this is a china tablet
and the backlight flickering is really annoying
U30GT MS TOUCH SCREEN PROBLEM
Hello
So I read the forum and saw that the rom posted here did not work correctly with MS models, unfortunately, I unknowingly install this rom, and now does not work touch tablet, and suddenly makes unexpected reboots, wanted to know if found the solution to this or if you changed the rom to the MS: (. Sorry for my bad English
Checking 51cube.net I see a firmware dated 1 Feb 2013. I'll see if I can get a download and work up a ROM kit.
Sent from my U30GT 2 using Tapatalk 2900Supersport
freaktab developer
RE: U30GT MS TOUCH SCREEN PROBLEM
Originally posted by 900supersport View PostChecking 51cube.net I see a firmware dated 1 Feb 2013. I'll see if I can get a download and work up a ROM kit.
is possible to install the original rom without problems while working on a kit for this model? I'am very grateful you
The steps to install the Original Rom are the same?
i download this http://www.51cube.net/ch/DownShow.asp?ID=135
regards
There are currently 2262 users online. 0 members and 2262 guests.
