[ROM] ARNOVA 8G2 8Gb [ROOT, Market, Google apps, ext4 fs, 1Gb user space]
    All the actions you do at your own risk!
    In applying the Custom ROM you lose your warranty
    Attention!
    Not suitable for ARNOVA 8G 4Gb
    This ROM is not suitable for a model with a resistive touch.
    Custom ROM version 5.0s release candidate for the ARNOVA 8G2 8Gb
    In the archive:
    - image\AN8G2_v5sRC.img - very flash
    - RK29BachTool_v1.4 - a tool for firmware
    - Drivers - USB Drivers for ARNOVA flashing mode.
    Flash only through RK29BachTool!!!
    Rolling back to the stock firmware is also only through RK29BachTool
    Differences firmware.
    - Sections converted into a format the ext4 file system
    which is much faster read/write data
    allows to edit, add and delete files in it.
    - Set aside for user data 1Gb memory. This will allow
    install more applications.
    With the increasing number of applications increases the start time.
    - Updated some applications.
    Thanks fenice57
    - Added support for modules BT, *
    - 3g USB-modem Hauwei models E1550 E1692 E1750 E1820 *
    * Requires verification and debugging.
    Flashing:
    Connect ARNOVA to the BB via USB-cable.
    At 2 seconds, press the "reset", you hear the sound of the columns twice.
    If the driver is not installed, install it.
    In Windows devices should see:
    | Class for rockusb devices
    -- RK29 Device
    Attention! Be sure to remove the SD-card before flashing.
    Then run RKBatchTool.exe
    Select the firmware and click "Restore"
    Updated the ROM. 14.02.2011 23:55
    - Fix VideoPlayer
    - Fix FlashPlayer
    ROM -> ARNOVA 8G2 8Gb [ROOT, Market, Google apps, ext4 fs, 1Gb user space] (81 Mb)
    Rolling back from the version 4s & 5s with only Rk29BatchTools through the button "Restore"
    User data during installation are removed.
    Dump the standard ROM AN8G2_rkdump.7z
    Archos 7c HT (My Custom ROM production) -> ARNOVA 8G2 8Gb (My modification MorkaMod JB v.1.2)
    Chinese STAR A5000=>Star N8000 (My Custom ROM production)
    Thank you once again. You are a genius!
    I have installed this rom two hours ago and it works very well.
    One minor thing is that the video player app crashes on start. I recommend to use MX Video Player from the market.
    At the moment my tablet eats the battery like mad, but I don't think that this has something to do with this new rom. I will check this out later.
    Bluetooth file transfer to my mac book works very well.
    Greetings from Germany
    P.
    Edit:
    Battery consumption seems to be ok now.
      Wahoo!!!!!!!!!!
      a
      n updated..
      flashed and reinstall all apps..
      so will report back soon with issues etc....
      Thank you for the stirling work....
        Looking GREAT Sowa. Love the battery indicator!!
          Hi guys,
          Just got my hands on an 8G2 and was wondering if someone could let me know when the download link for this custom rom will be back online. When I try to download the server states the file doesn't exist.
          Looking forward to joining the tablet community, have been running different rom's on my DHD for a while now and am hoping to start learning to contribute to the projects.
          Cheers in advance,
          Blinky.
            I am not sure. I did find a file called AN8G2_v5sRC.7z that the link is to now, but not sure if that is Sowa's final or not? I would wait for official word from Sowa before you flash this ROM.
              Thats the file i was looking for, the download is working again, it's not the final release its a release candidate.
              Cheers
                The FTP was only down about an hour on Sunday while I was rearranging our servers at the co-lo. I am pretty sure this is Sowa's release candidate not his final.
                  I have found serious flaws in the published ROM so that stopped the download.
                  Approximately 1 hour later upload the board version.
                  I offer my apologies.
                    There's not only the battery indicator
                    I have a lot of things have changed in the graph framework-res.apk
                      eeer does that mean I have to redownload this rom and reflash?? just got it set up almost perfect! I noticed the fixes are flash and video could you not just provid the correct files to manual install ourselves(already installed flash and use mxplayer for video any way)..Would save time for those who have flashed already and as I have 300+ apps installed is a damn pain to start fresh if only minor issues!
                      as to bugs... manage apps in settings FC's for me and g-sensor are off up=up down=down left=righ and right=left!! annoyingly funny but game play is terrible as a result! Also is it safe for me to use my own boot animation?
                        1. I noticed the fixes are flash and video could you not just provid the correct files to manual install ourselves
                        2. as to bugs... manage apps in settings FC's for me and g-sensor are off up=up down=down left=righ and right=left!! annoyingly funny but game play is terrible as a result!
                        3. Also is it safe for me to use my own boot animation?
                        If you know how to replace applications that do not need to reinstall.
                        1. VideoPlayer - needed replace VideoPlayer.apk & VideoPlayer.odex
                        If you are running FlashPlayer, no need to do anything. Otherwise, you need to replace flashplayer & install Adobe_Flash_Player.apk v.10.3 (before delete v.11).
                        2. The problem is the native firmware. As a workaround see here http://www.freaktab.com/showthread.p...ull=1#post2085
                        3. If the question is to replace /system/media/bootanimation.zip, then please.
                        boot.img do not touch!
                        Necessary to replace the items can be downloaded here: https://rapidshare.com/files/512903992/For_Replace.zip
                          Hi thank you for your reply...It's good news not having to Re-install everything thank you for the update file.......
                          As to the workaround you indicated that works for apps that rotate screen the wrong way wrong and for apps that don't rotate to landscape but doesn't resolve tilt control issue... Some games the controls are correct (tilt left = left, tilt right = right) but others are incorrect(tilt left = right, tilt right = left) its most annoying as seems to happen it car,or aircraft sims mostly... Just wish there was a fix...
                          Anyway first impressions of the rom are GREAT!!! Loving the stability and speed...So fluid now... Still a few minor issues as mentioned but thats fine as all are liveable...
                          Keep up the great work..
                          And if you have a A8G2 8Gig flash this rom!!!!
                            Trying to get this onto to my tablet I've run into a severe problem, I'm running Windows 7 SP1 and it seems that I get the driver to work, my tablet won't come up in the batch thing.
                            I have tried everything it did work on an XP machine, but not on this. Everything is upto date.
                            Any fix?
                              I have theARNOVA8 G2, after flash, the touchdoes not work andcan't find theoriginalromto download.is there anysolution?
                              note: greatwork
