[ROM] ARNOVA 8G2 8Gb [ROOT, Market, Google apps, ext4 fs, 1Gb user space]
    Originally posted by ViciiuZ View Post
    I have theARNOVA8 G2, after flash, the touchdoes not work andcan't find theoriginalromto download.is there anysolution?
    note: greatwork
    Thank you for reminding me. Added to first post.
    Touch is working properly. We must wait messages about successful completion of the calibration. When prompted for the registration akkunta Google, click "back" and wait for the next.
    Originally posted by mrv321 View Post
    Trying to get this onto to my tablet I've run into a severe problem, I'm running Windows 7 SP1 and it seems that I get the driver to work, my tablet won't come up in the batch thing.
    I have tried everything it did work on an XP machine, but not on this. Everything is upto date.
    Any fix?
    Try again to install the driver in the flashing mode in accordance with the instructions. I also have Win7 SP1 x64 and no problems.
    Archos 7c HT (My Custom ROM production) -> ARNOVA 8G2 8Gb (My modification MorkaMod JB v.1.2)
    Chinese STAR A5000=>Star N8000 (My Custom ROM production)
      I have followed the guide however it says Class for rockusb devices -> Unknown device, I've uninstalled and reinstalled everything no luck, I will have to find another computer.
      One Q: Does this ROM support iptables? If not do you know any roms that do, I need it to access the internet.
        thank you very much for responding so quickly.
        I read on there, this cfw is forcapacitive screen.I hope that calibrate the screen, but remains in a loop and never ends.
        update: i managed to install the firmware [
        AN8G2_rkdump.7z] , but i got same error, the touch don't work
        my screen is the resistive
          Ops!
          This ROM is not suitable for your model.
          First became aware of AN8G2 with resistive screen.
            And since Arnova does not havce a downloadable updating.img, Sowa would not be able to do a ROM unless someone with a new Resistive screen model does an ADB dump before flashing any other ROMs.
            We need to have a ROM dump to even begin to try and make a ROM for the resistive screen version.
              Ops!
              omg
              but have any solution? I get my tablet this monday
                omg
                I'll try to make a ROM, where the exceptional start assistant and tool calibration screen. Maybe this will help. I did a ROM for A7CHT (capactive touch) on the basis of ROM for ARNOVA 7 G1 (resistive), where it worked.
                To make sure the plant needs a dump of the stock firmware on your model.
                  sorry my poor english ~ don't understund.
                  where can i get this?
                    Revise su correo electrónico personal en este sitio.
                      just had a very odd issue...the memory suddenly corrupted resulting in a complete loss of everything and also a full reflash.... oddly after reflashing everytime I after a few app reinstalls everything would FC's and I do mean every app too!!!! reflashed v5 again and still same issue.... so reflashed v4 of rom and all ok then reflashed v5.... and it fine again.... it would seem that when v5 reflashs(upgrade or other option) it doesn't format correctly or deep enough where as v4 does. anyway there may be an issue with v5 which corrupts everything but may just eb one of those things but there is def a problem with v5s formatting when flashing the device...
                        Thanks for the valuable information.
                        I still had no such problems, but for a long time and work on one proshivek does not work.
                        Constantly alter for debugging.
                        What message is it?
                        How much free space in the userdata after installing 250 applications?
                          there's no message other than the annoying popup with where only option is to force close...Oh sorry you mean the message on the popup it mentions Android.process.acore ... sorry but didn't write the message down as was in need of getting the tablet fully working again as needed for work... as to user space eeeer didn't get chance to look as the popup would just constanlty be there... but with the tab now fuly working again I have 224megs free with 320 apps installed..and theses are the reinstalls...
                            ok so its happened again...the fc's are all back... all was well and then su,titanium,root explorer,hotmail,eZpdf,Opera,maildroid, oh heck the list is way too long.... but they ALL FC soon as you use them....This has now become the rom from HELL..... There's 60megs of system and 210megs of user data free..Each FC's popup is slightly different so listing them would be somewhat pointless and very lengthy and time consuming...
                            Going Back to 4.1/pos first v5 not the update as at least that one worked with out issues like this....
                              Have you tried flashing the rom and installing each program one at a time. I have the same rom running and no FC at all.
                              I also have been playing with the build.prop file and still don't have any FC's
                              The only FC I get is after flashing, the calibration for the touch screen
                              This seems to be a known problem.
                              It may be one of the programs that is causing the FC's, I know its a long winded solution but might work.
                              Good luck,
                              Blinky
                              Sent from my HTC Desire HD using Tapatalk
                                @Sowa
                                Alright mate, using your rom on v5 at the moment, lovely rom cheers. I am trying to squeeze as much speed from the rom as possible and wondering if I could get some advice from you.
                                I am editing the build.prop file and that all seems good so far. The edit I'm trying to achieve at the moment is the read ahead for the internal memory. I found links online but the folders do not exist on the rom, do you know which file I need to edit to alter the read ahead value.
                                I am trying to see if different values will increase the memorys speed.
                                Cheers in advance,
                                Blinky.
