MK808-B "V2 Sunvel Clone" - Finless 1.6 Custom ROM
    OK folks here is my MK808-B 1.6 Custom ROM for the "Sunvel" clone
    If you MK808B is flashed with my previous 1.6 ROMs and you find Wifi and/or Bluetooth does not work, then you probably have this Sunvel clone. This ROM is for you guys.
    ______________________________
    Features in 1.6 ROM:
    1) Optimized for scaled up 720 to 1080 for best look!
    2) Fully rooted with the latest SU and SUperUser.apk
    3) 2 gig of user APP space. Stock was only 1 gig
    4) Debloated of junk APPs you an get back from Google Play
    5) FULL GOOGLE PLAY mods! Onlive and other Apps should show up now.
    6) This also includes mods to framework to fix gameloft games that crash to desktop e.g. like wonder zoo.
    If you want more compatability, you must edit build.prop. See Freaktab.com for that info.
    7) Special add for this ROM. Full init.d support! If you do not know what that is... ignore it.
    If you do, you can now install and use boot time scripts like V6 SUper Charger!
    8) All APPs are up to date! So you will not get any Google Play APPs needing updated.
    9) Cleaned up the file system so it is not fragmented! Basicly I used linux tune2fs when making the images.
    10) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
    11) The Xbox XPAD.KO module is now injected on boot. This was by request! Enjoy!
    12) TUN KO module were also added by request.
    13) Added Xbox control .kl and .kcm files to fix camera spin in some games.
    Also please help with the readme.txt for flash mode instructions. Since I do not have one of these there maybe better ways to put it into flash mode. The current readme is following my MK808 instructions.
    So you folks with the MK808B "Sunvel" Clone can try this ROM and provide me feedback for improvements.
    ROM DOWNLOAD -> MK808B "Sunvel Clone" Finless 1.6 ROM (221 megs)
    Woww, that was quick!
    Will try it in the afternoon and report back.
    Sadly I had many freezes and reboots with the stock SunVel ROM, but hopefully not with this one.
      hello
      how can I know if it is a Sunvel with bluetooth or without bluetooth
        with bluetooth u have 2 antennas
          Oh crap...
          I think I got a faulty unit: random freezes and reboots with stock and this fw.
            @Finless: All is OK wifi @ bluetooth, root OK, but when i powered in dc slot in max 5 minutes the sistem freeze, in OTG has been running OK for 2 hours. Best regards and 10x
              keep power on OTG port and all is OK
                thank I have bluetooth version
                  Very odd. My Sunvel stick does power fine through either USB port. It did not until I got the Sunvel ROM. I left it on overnight using non-OTG port and this AM it was still on.
                  I was powering it from my PC USB port.
                    Seems that you are right and that also explains why there were no freezes/reboots with the v1 clone ROM. (Otg only...)
                    It wouldn't be a big deal if it powered off normal, but it always reboots and you have to plug it out in time.
                    Don't know if I should keep it or return it for another model.
                      I tried this room the MK808b does not boot by OTG and USB
                        Originally posted by enzofr View Post
                        I tried this room the MK808 does not boot by OTG and USB
                        This is MK808B, not MK808....
                          Bob after trying many different RONs and racking my brains as to why my unit would not work I tried this and it worked perfectly! Powers up from correct port without a problem, no freezes (touch wood), wifi and Bluetooth both work. Wifi abit slower than other rom but nothing to worry about.
                          so thank you for all your help, I've read and re-read many forums and posts and finally got it going.
                          so now just need to fix the xbmc no dependancies issue I now have and I'll be on track!
                          Merc
                            for me it is very strange that the only ROM is boot Finless 1.6 for MK808
                              Seems like my SunVel is faulty:
                              Powered with dedicated port: often freezes and reboots.
                              Powered through OTG: first freeze after 3 hours of flash video - second freeze after 1.5 hours of flash video and it doesn't reboot on it's own like when powered with dedicated port.
                              The device doesn't seem very hot (on the outside) but may it by a heating problem?
                              I'm thinking of getting a heatsink for it - maybe this one. (would fit exactly the SOC)
                              Do you guys think it's cause of the heating? (1.6 GHz, FlashPlayer and no heatsink)
