MK808-B "V2 Sunvel Clone" - Finless 1.6 Custom ROM
Re: NEW - MK808-B "V2 Sunvel Clone" - Finless 1.6 Custom ROM
Originally posted by philocritus View Postquick question.
does anyone know if the omegamoon kernel works on the sunvel clone with this rom?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Hi all first let me say what a cracker of a site this is and hello to everyone!
I have mk808-B V2 sunvel clone and have tried MK808B Clone Finless 1.6 BETA2 but BT does not work and also the Ethernet turn on/off has gone from the settings menu, having a mini usb to ethernet connection, which worked on the original stock rom, does anyone know if this has been added to this version 2. As for bob, simply put your a legend and sometimes you must feel like banging your head against a brick wall, but without people like yourself, we would all have to put up with stock roms and how boring would that be. Thanks and keep up the good work
Just a quick update, installed v2, Ethernet turn on/off is back but not working(shame) Wifi drops out after about 5 mins, also remote app not working(not seeing device, could be down to wifi problem), as it was on MK808B Clone Finless 1.6 BETA2, thanks/Last edited by canford; 25 February 2013, 00:03.
Originally posted by Finless View PostOK folks here is my MK808-B 1.6 Custom ROM for the "Sunvel" clone
If you MK808B is flashed with my previous 1.6 ROMs and you find Wifi and/or Bluetooth does not work, then you probably have this Sunvel clone. This ROM is for you guys.
______________________________
Features in 1.6 ROM:
1) Optimized for scaled up 720 to 1080 for best look!
2) Fully rooted with the latest SU and SUperUser.apk
3) 2 gig of user APP space. Stock was only 1 gig
4) Debloated of junk APPs you an get back from Google Play
5) FULL GOOGLE PLAY mods! Onlive and other Apps should show up now.
6) This also includes mods to framework to fix gameloft games that crash to desktop e.g. like wonder zoo.
If you want more compatability, you must edit build.prop. See Freaktab.com for that info.
7) Special add for this ROM. Full init.d support! If you do not know what that is... ignore it.
If you do, you can now install and use boot time scripts like V6 SUper Charger!
8) All APPs are up to date! So you will not get any Google Play APPs needing updated.
9) Cleaned up the file system so it is not fragmented! Basicly I used linux tune2fs when making the images.
10) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
11) The Xbox XPAD.KO module is now injected on boot. This was by request! Enjoy!
12) TUN KO module were also added by request.
13) Added Xbox control .kl and .kcm files to fix camera spin in some games.
Also please help with the readme.txt for flash mode instructions. Since I do not have one of these there maybe better ways to put it into flash mode. The current readme is following my MK808 instructions.
So you folks with the MK808B "Sunvel" Clone can try this ROM and provide me feedback for improvements.
ROM DOWNLOAD -> MK808B "Sunvel Clone" Finless 1.6 ROM (221 megs)
and also the link seems to be broken any chances of getting the correct link ??
thanks mate !
Yes, can someone PLEASE re-post this 1.6 sunvel firmware. I want to try it. I was using Finless 1.7 sunvel but it stopped working after a month. Device now stuck on two penguins on power up. Reflashing 1.7 does not fix? Some other roms work but no wifi...
UPDATE:
I found a temporary fix, I guess...
The Finless 2.0 rom for the MX1/2, in the Imito MX1 forum seems to work for the MK808B V2 clone motherboard marked Sunvel 1808. Wifi works but Bluetooth does not.
If anyone knows a better rom / fully working rom, then please post.Last edited by relaxxxrrr; 19 September 2013, 19:06.
The download link is broken. Please fix.
Originally posted by credinho View PostThis link is not working, does someone have this ROM or a different link that I can use?
Originally posted by Shomari View PostIf yours has the MTK chipset which it does if it's the model mentioned above, you're in luck, you can install KitKat 4.4.2 http://www.freaktab.com/showthread.p...Fully-Working)
There are currently 2690 users online. 1 members and 2689 guests.
