[ROM][ICS] Elektricity ROM - PMID4311
    *********NOTE: BEFORE FLASHING, PLEASE CHECK TO SEE IF YOU HAVE A NEWER PMID4311. IF SO, PLEASE READ THE POSTS BELOW-YOU MAY ACTUALLY IN FACT HAVE THE EMERSON 543 BRANDED HARDWARE IN A PMID4311 CASE! IF THAT IS THE CASE, DO NOT FLASH THIS ROM, USE THE JELLY BEAN VERSION INSTEAD!!!!**************
    Introducing Elektricity ROM ICS!
    New in 0.1 (Initial release):
    • Force GPU rendering for speed (checkbox not ticked by default, even though it's enabled).
    • Build.prop tweaks for speed
    • Wifi tweaks
    • Incorporated LiquidLimez Google Play fixes
    • NAND reformat, providing a 384mb system partition (Removed OEM partition).
    Features:
    • Based on latest stock Polaroid ICS
    • Rooted
    • Latest Google Play installed by default.
    • Busybox updated to latest version
    • init.d support by default
    • Scripts for speed added
    • Latest CWM recovery
    • Petrus' 'Reboot' application. Features:
      • Reboot
      • Power Off
      • Reboot into CWM recovery
    • Apex Launcher enabled as default launcher
    Thanks to: 900supersport, petrus, Tattman65, Finless, LiquidLimez, dolorespark
    Installation instructions:
    ***NOTE: IF YOU ARE FLASHING FROM THE STOCK ROM, PLEASE REMOVE YOUR EXTERNAL SD CARD BEFORE FLASHING-IF YOU DO NOT, YOU MAY LOSE YOUR DATA!!!!***
    • Follow these instructions with the exception noted below (No reason to re-invent the wheel): http://southerntelecom.com/polaroids..._pmid4311.html
    • In step 17, instead of using "PMID4311-20120712.img", you'll obviously want to select "4311_elektricity_rom_v_01.img"
    • 'LET IT SIT' for at least 5 minutes before doing anything to let the ROM "Settle".
    • Reboot (I just added this step as a 'just in case things aren't quite working the way you want')
    Problems after you flash?:
    PLEASE DO NOT REPORT PROBLEMS IN THIS THREAD until you've confirmed you followed the above instructions EXACTLY. Please don't report the problem in this thread until you've tried a factory image install first to see if that cures the problem.
    CHANGELOG:
    See post #2
    DOWNLOAD (New location):
    https://public.bay.livefilestore.com...ion.png?psid=1
    Features:
    • wifi tweaks
    • Added Google Play
    • Init.d support (and Init.d tweaks)
    • CWM recovery
    Files updated:
    • everything in the /permissions folder has been updated to LiquidLimez files
    • build.prop
    Known issues:
    • Apex Launcher needs to have the 'behavior' set from 'default' to 'auto-rotate' in the launcher settings to have the home screen display in portrait mode-this is specific to Apex Launcher (and I'm guessing due to the size of the display of the PMID4311)
    Installation:
    • See Post #1
    Changelog:
    • 0.1
    Installation:
    • See Post #1
    Elektrik recommended files:
      I tried the ROM, I have a Polaroid PMID4311, the same tablet and after installing the ROM, I get no touchscreen after powering on, I followed the directions completely with no problems. Why is this?
        Try the update.zip from dolorespark's post. My ROM is based on the stock, so dolorespark's theory may be true:
        "Compatibility & Bugs
        The very newest Polaroid 4311's may actually be Emerson 543's in disguise - there's no way to tell from the outside. If your touchscreen stops working after flashing the 4311 version of the update zip, try the one for the 543."
          http://www.freaktab.com/showthread.p...highlight=4311
          Thank You! That helped. Now since I have a machine in a different case, is it ok to freely install a em543 ROM or anything else related to em543?
            I'm not sure, but if flashing that update.zip worked I would assume so....
            for reference, could you tell me which file you used? Was it this one?: 543-dopa-framework-20130108.zip
              Yes that is the file, but I used both files, 1 being the ROM I assume.
                good to know but if all you did was flash both files you only upgraded from my ROM (ics) to jelly bean. I was looking to see if his zip file fixed the touch screen issue on your 4311 with *my* Rom. no biggie though, i'LLC just change the warning
                  good to know but if all you did was flash both files you only upgraded from my ROM (ics) to jelly bean. I was looking to see if his zip file fixed the touch screen issue on your 4311 with *my* Tom. no biggie though, i'LLC just change the warning
                  Ok, well I believe that the first one to install is just the recovery which I had to install via livesuite, and the second through the recovery. Is it possible or do you have a way of installing your ROM via recovery?
                    nah, not yet-reason why I'm still pre-1.0. got lots to do before then
                      Just wanted to give a big thanks to elektrik for all the hard work on this rom. Installation went perfectly the first time on my 4311. The performance is surprisingly good on this little $55 device. I'm having a ball using it as a media/email machine. My phone is a better device in every way but maybe knocking this little thing around will extend the life of the phone.
                      Thanks again for all you do.
                        Sure! I'm a bit overwhelmed at work, but wait until this little bad boy gets the tweaks of my latest ROM ;-)
                          Re: [ROM][ICS] Elektricity ROM - PMID4311
                          Is there a way to make this ROM work with the EM543? I got Dopa's CM Jellybean ROM working but performance isn't as responsive as the stock ROM and everything looks compressed, icons chopped off, etc... Apex launcher seems slow. I would prefer stock with latest Google Play.
                            I would have to research it, but to be honest, I don't have the time. I *believe* the specific touch screen file that is different from the EM543 and the 4311 has been mentioned in the forums-you could try to find that file and replace it on your EM543, but do so at your own risk-I don't make elektricity ROM for tablets I don't own and I don't own that tablet.
                              Hey, I seen that the Polaroid site has a new update available with the fix for the TS; do you think you can rebuild your ROM with the TS fix included?
