[ROM][ICS] Elektricity ROM - PMID4311
Originally posted by trae View Post
Originally posted by elektrik View PostYes and no. I can technically do it, but honestly, Polaroid has two different types of PMID4311's (at least it is suspected) so I would run the risk of breaking one to fix the other. If you know the specific file, you could just use an ADB connection and copy it in manually.
Originally posted by trae View PostHow do I go about doing that? It shouldn't be a problem. I noticed that the new update is already rooted too.
adb commands
Originally posted by elektrik View Postsure- You obviously need ADB installed (part of the android dev kit or downloadable in various forms on the web). connect the tab via usb while it's on (and run the appropriate adb commands) and voila!
what would be the adb command to flash the .img file and what mode does the tablet need to be in?
(What if it doesnt boot all the way?)
I cant seem to get Windows to see the device so Livesuit isnt working. I think I can do the img file in Linux using adb but I'm not sure how to set that up.
thanks in advance
There are currently 2217 users online. 0 members and 2217 guests.
