ANOTHER CLONE! UG802_9 or UG80x? Stock ROM now available
Originally posted by Exlo View PostThis looks exactly like the one i purcased from ****, and mine works fine with BETA 3 in this thread.
Sent from my GT-I9300 using Tapatalk 2
Sorry for double post.
Originally posted by dorud82 View PostCan you tell me how do you do that? Because i conect my stick on the pc and nothing happened ,not detected. Thank you .
Originally posted by evgenyk View PostIn preference/usb checkbox "connect to pc". You need to install drivers (included in any fineless firmware set)
Originally posted by dorud82 View PostI got succed,but the first time have been stuck on boot ,then i find the 2 pin and shortcut them and i flashed again (this time i erase NAND).works good but antutu gives me a lower score that the original rom.How can i turned on after i switch off? Only unplug and plug in the charger? At original rom was left and right click on mouse.
Originally posted by evgenyk View PostI plug in otg usb into usb LCD and switch on/off by tv remote. Also, you can install "Reboot" application (root is needed), there is power off option
boot loop
My upgrade went well and i was setting up mu UG802 but now I'm stuck in a boot loop. i have done some research and can't find the jumper points for this configuration. Any ideas?
I got it to work it is the E02 jumper but it didn't work till i soldered it. but you can't have it jumped when loading. I the end i cleaned it up with some fresh solder and used solder wick worked well as the temp jumper.Last edited by iwolf; 28 May 2013, 03:48.
Hi all,
first off, many thx to Finless for putting such an endless effort in creating ROMs for all of our (cheap) china clones
So instead of just taking your beta3 I just registered to ask if/how I shall take a new dump you can use for a new Finless Rom.
I got exactly the same Board Layout like in the start post but like #5 with Hynix (instead of Elpida) and RTL8188EUS Wifi Chip (instead of Ralink)
with stock image from 23th january 2013, Kernel 3.0.8+ incl. 1080p mode
btw. as a comment to #5: the 4x H5TQ2G83CFR-H9C are 256MB (2gigabit) DDR3 1333 Chips which sums up to the 1GB available Memory
In my image the usable space from the 4GB H27UBG8T2ATR chip is mapped in form of Storage Layout: 504MB internal and 2,09GB NAND Flash
I've also attached an Hardware Info Report (guess the reported sensors are all fake though)
HWinfo.zip
Interstingly the Display size is reported as 1280x672 (not even 720p) even i have set 1920x1080p-60 in Settings>Screen>HDMI mode and my monitor is reporting fullHD 60h as input.
So kindly tell me if a new dump would be of any use for you as i'm already dying to try out Finless on the device
Greetz, Nord
PS: based on the build info, that should be the same device like www.freaktab.com/showthread.php?3382 (just a newer build date of the image)
Originally posted by Nordmann View PostThx Bob,
so would a newer stock dump be of any use for your Development for this device?
I would give this a try then:
www.freaktab.com/showthread.php?3622
Regards,
Nord
There are currently 2196 users online. 2 members and 2194 guests.
