ANOTHER CLONE! UG802_9 or UG80x? Stock ROM now available
    Ok there you go:
    UG80x_Stock_20130123.7z
    191 MB | 200.719.766 Bytes | CRC32: EDED99E9 | MD5: F90A2CF361C7007E35C4D5CC9F4DDF5B
    As I said this is/was my Stock rom, build info rk30sdk-eng 4.1.1 JRO03H eng.box.20130123
    Got the version with Hynix Memory chips but shouldnt matter for the Image.
    Please be warned, I did not flash this back to any device yet! so cant confirm its working.
    Should be flashable with RKAndroidTool (e.g. included in Finless's Package) once device is in FlashMode.
    For the recovery.img I also included a dump with the offset/length numbers not reverted,
    but I guess it was just a misstake by 900supersport, details in his thread
    So I hope this will be of use for someone.
    @Bob
    Maybe you can check it out, e.g. for newer drivers in the kernel image or smth.
    Would love to see Finless 1.8 on this ♥
    1.7B3 already rocks
    Greetz,
    N0rd
      Updated IMG
      I just got an update from seller to my clone, and thought I`d share this with you guys
      UG80x_9 Finless 1.7 BETA3 ROM also working well with my stick.
      Its sold as a MK809 and looks exactly like in the images borrowed from dorud82 in this post.
      The date states 2013/03/12 and its exactly as given to me. I have not tried this my self, since I`m very happy with 1.7Beta3
      -Exlo
        It seems a lot of sellers are now using my ROMs.
        Glad your happy!
        So you know I do not care if they do. Just super happy people are getting the best they can from what they bought!
          Thank you guys! And i want ask you why when i reboot it loose the network connection and shows the clock 2:00 ,date 1sept 1970? Then i must power off and turned on to get in good condition.
            What is best new rom for my clone?
            my clone is this
            Thank you so much
              my clone is this
              Thank you so much
              http://i50.tinypic.com/2uzbdkg.jpg
              Try Finless 1.7 beta3 , i have the same clone and it's working good.
                Ciao, Finless.
                I have one of these clones, and almost bricked it. With the infos found in this forum, i was able to recover the little nasty thing, and now it works very good.
                Thank you very grazie
                BTW, i flashed your UGx_9 1.7 beta 3, and WiFi work good enough.
                Happy moddig to ev'rybody
                  More info on this device here: http://linux.autostatic.com/unknown-...device-tidbits
                  So ED1 (or T5 + Gnd) is flash mode, ED2 (or T6 + Gnd) is recovery mode, ED3 and ED4 are probably (and hopefully) TX and RX for serial console access. I've soldered a reset button on it myself so I can easily boot it into flash mode.
                  I managed to brick this device but by flashing it with beta 3 ROM it came back to live. So many thanks for this ROM and the tools that come with it!
                    Hi all,
                    I have an UG802 clone, but the one with mic and "camera/flash" button near HDMI port.
                    I've tried almost any ROM i've found on the forum but many simply does not work, other boot loop and the better one, this 1.7 beta3 does not have wifi
                    I've reseted many times, with sd in, without sd, with my wireless keyboard, without it...
                    And every time I shut down the minipc lost the date/time.
                    Any idea of what can I do?
                    Is there any 4.2 firmware version? fully working ?
                    Thanks for the enormous effort ... and the help
                      Hi everyone,
                      New around here. I'm trying to help a friend out and flash his device.. turns out it's one of these:
                      " Originally Posted by realduffsWhat is best new rom for my clone?
                      my clone is this
                      Thank you so much
                      http://i50.tinypic.com/2uzbdkg.jpg"
                      I see some people are having success with the Finless 1.7 beta 3 - can I just flash it the normal way, or is it necessary to open it up and mess with pins?
                      Thanks in advance!
                        Android 4.2.2 from rikomagic mk802III for ug802 clone!
                        Hi all. I have install android 4.2.2 ( from 27.08.2013)from rikomagic mk802III on this ug802 clone Click image for larger version
ID:	430767Click image for larger version
ID:	430768 everything works like a charm , but the stick is getting hot(only when i run antutu) and reboot.I downgrade the cpu clock to 1272mhz but no succes. I wonder if anyone can help me in this problem ,especialy Bob or Neomode , maybe can do something on this rom to work on my stick. Thank you.
                          problem with Wifi
                          Hello,
                          I have a TV stick called Arena scientific TV-505
                          I'm having problems with wifi (not enabled)
                          i opened the stick and T002 V2 20121207 written
                          has Rockchip RK3066
                          and other 4 x GeIL chips ( i guess ram)
                          Realtek RTL8188EUS wifi chip
                          and SanDisk chip
                          it has a reset hole and i use it for recovery mode
                          i tried allot of firmwares and wifi is not working
                          i think it's UG802 from all the talk i've seen but maybe i'm mistaken
                          in the logcat i see:
                          D/WifiHW ( 265): Read wifi chip type OK ! wifi_chip_type = RTL8188EU
                          D/WifiHW ( 265): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/8188eu.ko, DRIVER_MODULE_ARG =
                          I/WidgetPrefs( 3393): Loaded widget prefs for 4
                          W/CommandListener( 80): Failed to retrieve HW addr for wlan0 (No such device)
                          D/CommandListener( 80): Setting iface cfg
                          E/WifiStateMachine( 265): Unable to change interface settings: java.lang.IllegalStateException: command '133 interface
                          setcfg wlan0 0.0.0.0 0 down' failed with '400 133 Failed to set address (No such device)'
                          E/WifiHW ( 265): Unable to open connection to supplicant on "wlan0": No such file or directory
                          I/wpa_supplicant( 7295): rfkill: Cannot open RFKILL control device
                          E/wpa_supplicant( 7295): nl80211: Could not configure driver to use managed mode
                          E/wpa_supplicant( 7295): Could not read interface wlan0 flags: No such device
                          E/wpa_supplicant( 7295): wlan0: Failed to initialize driver interface
                          please advice which firmware to use to solve wifi problem
                            Increase cpu/gpu frequencies?
                            OK here is BETA 3 version.
                            I sure hope this fixes wifi!
                            ROM -> UG80x_9 Finless 1.7 BETA3 ROM (225 megs)
                            Hi Bob! I want to ask you if you want or if you can change the frequency of the CPU and GPU on this rom as 2dark4you & finless 1.7 cpu1272Mhz, GPU 466Mhz, ram1140Mhz because I installed 2dark4you & finless 1.7 rom (1272Mhz, 1608Mhz overclock) but cpu stay stuck at 1008mhz, not up to 1272mhz. I tried with the kernel's 2dark4you 1.7beta 3 finless but still it remains at 1008mhz. Finless cpu frequency to 1.7 beta 3 is 1200MHz, the gpu not know. I have tried many roms but this works best. Please, I and users of clones ug802. Thanks in advance. Have a good day!
                              Hi
                              Try Mine mate http://www.freaktab.com/showthread.p...fi-%28Fixed%29
                              Originally posted by waelaase View Post
                              Hello,
                              has Rockchip RK3066
                              and SanDisk chip
                                4.2.2 clone firmware. Fully working. 1080p
                                Enjoy
                                ftp://public:[email protected]/k9/
