MK808 JB 4.2.2 - Finless ROM 2.0 - BETA
    Netflix bug?
    Thank you Bob!
    All work great except for Netflix. The image is scrambled , the sound is ok. All others players is ok.
    sorry for my bad english.
      Originally posted by Limitless83 View Post
      Just ordered my MK808B from geekbuying
      and eagerly waiting to receive it
      and i have a couple of questions:
      - what keyboards are supported ( i have several lying around logitech/medion/...)
      - what about printers? (crazy question i know, but since i stopped gaming, i'm looking to replace my pc)
      - are there any other roms out there (cyanogen/miui/...)
      - on my tablet and phone i use Pimp my Rom
      is it safe to use, or is it possible to implement some of the tweaks?
      original forum link: http://forum.xda-developers.com/showthread.php?t=1908269
      Thank you allready Bob for all the hard work you've done allready, and congratz on the sponsorship from geekbuying, i hope you continue to improve our tv sticks
      Hardware Device Compatability List:
      Put other questions in another thread. This thread is dedicated functionality for version Finless 2.0. This makes it more organized.
      Take a look at some threads here:
      MhagnumDw
        keyboard layout notification issues
        Have just loaded and run 'Finless ROM 2.0', seems to work really well, thanks. But I was hoping that running a new rom might fix a recurring problem I'm having with the 'select keyboard layout' notification. If I'm watching a youtube video for instance, the notification seems to cause the webpage to reload and start the video from the beginning again, every 2 or 3 minutes. Every time the notification comes up it freezes the cursor, or makes it disappear, regardless what app is running. Have disabled notifcation in the app settings, disabled the app. Altering every setting doesn't seem to help a bit. Have done a backup and reset, reloaded the finless 1.7, now running Finless ROM 2.0, but still doing it. Any idea what the trouble might be?
          WiFi Display
          Is this what is needed for the WiFi Display / WiMo App to work?
          TV Stick: MK808 // Tronsmart T428
          ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
          CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
          Recovery: ClockworkMod
          Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
          Phone: Samsung Galaxy Note II
          ROM: Whompasaurus v4.2
          Kernel: Persus
            Re: NEW - MK808 JB 4.2.2 - Finless ROM 2.0 - BETA
            Your problem sounds like a wifi/USB bandwidth conflict. Are you using a wireless USB keyboard or air mouse with a dongle, operating on the same 2.4 GHz frequency as your wifi? If so, try plugging the dongle into an extension cable or a different port.
            I'm not the lowest of the low, but I am the slowest of the slow (49.5 mpg over 42k miles in Scion xB)
            MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
              ??? It looks like a replacement for our MK808xxxes. Isn't Wimo a remote app? How would this device do any better?
                compatible whit mk802III?
                hallo everybody,
                is this rom compatible whit mk802III like the 1.7 finless rom?
                anyone have tried?
                  Might not be a real fix, but I go into 'Manage apps' and disable the Android keyboard completely. I only use the real usb keyboard. If Google Now cause the 'voice typing' to pop up I disable it too since I have no need for Google Now with this connected to the TV.
                    F11 ?
                    Hi, updated from 1.7C to 2.0 Beta. Works perfect upto now.
                    Is F11 to unhide the status bar gone?
                    Also Ctrl Alt F11 isn't bringing back the taskbar.
                    Regards
                    Markus
                      Same problem for me on 808B
                      Originally posted by vnishimoto View Post
                      Thank you Bob!
                        Confirmed!
                        Netflix does not work on JB 4.2.2. The reason is the EGL changes they made near I can tell. You get the same scrambled screen if you flash a 3.0.8+ kernel with a JB 4.2.2 OS.
                        I think we will have to wait for a Netflix update.
                          R: NEW - MK808 JB 4.2.2 - Finless ROM 2.0 - BETA
                          Do you know if the Rom work on mk802III?
                          Inviato dal mio Galaxy Nexus con Tapatalk 2
                            Interesting. I found an article on the web that said on Feb 5th Netflix released a new version to support JellyBean. Hmmmm... Seems that Rikomagic messed something up in the ROM.
                            Makes me wonder if a build.prop mode will spoof JB4.1.1 and we get a different Netflix that might work.
                            I will play with this.
                              Fix for Netflix! Use the previous version!
                              OK guys I fixed Netflix if you will.
                              Read here:
                              http://www.freaktab.com/showthread.p...2-2-TV-players
                                Mr. Finless,
                                Excellent Rom. I use BSPlayer to stream vids from LAN and significant improvement (from 1.7) on MP4 and MKV file playback. Works flawlessly so far.
                                I noticed that I cannot get a few items from Google Play anymore, for instance SoundCloud and Speedtest.net say that device not supported. I use these on my Nexus 4 which is also a JB 4.2.2. Can you help with this?
                                Regards,
                                John
