MK808 JB 4.2.2 - Finless ROM 2.0 - BETA
You will get a far better answer if you post this question in the Gaming and TV stick forum. At this point we don't know that APP (I have never used it) and thus have no idea what ROM it works on let alone mine.
Does your wifi and bluetooth work at all?
edit: is that not a program to control a Win PC with an android and not an android remote?Last edited by Midniteoyl; 11 April 2013, 04:05.
Originally posted by Finless View PostYou will get a far better answer if you post this question in the Gaming and TV stick forum. At this point we don't know that APP (I have never used it) and thus have no idea what ROM it works on let alone mine.
its a combo of server/client apps released by Rikomagic and are told to work on both Rikomagic MK802II and MK802III, but not on MK808( probably because MK808 isn't Rikomagic ).
Originally posted by mopp View PostDoes anyone have a build.prop for google play store access?
I already tried some combinations but it seems not to work. I cleared the play store cache and rebooted after every modification.
Quick guide:
Open a terminal window (requires root access)
Mount /system as rw
# su
# mount -o rw,remount /system
Modify /system/build.prop:
ro.product.model=Nexus 7
ro.product.brand=Google
ro.product.name=nakasi
ro.product.device=grouper
ro.product.board=grouper
ro.product.manufacturer=Asus
Then I copied the XML files from the zip-attachment to /system/etc/permissions
Set the permissions with chmod 644 and changed the user with chown.
Go to Settings -> Apps -> All -> Google Play Store -> Force Stop and Clear Data
Reboot
btw. A lot of programs like vi or grep do not work in the ROM.Attached Files
R: NEW - MK808 JB 4.2.2 - Finless ROM 2.0 - BETA
Hi at all.
It would be possible and simple to change the Wi-Fi driver in the Rom?
It's possible put the driver for mk802III in this Rom? Thus do use this Rom in mk802III with Wi-Fi and not with Ethernet
Thanks you
Inviato dal mio Galaxy Nexus con Tapatalk 2
It is not possible at this time because the current KO modules that worked on 3.0.8 kernel will not work on 3.0.36+. So your just going to have to wait until someone figures out how to recompile them.
Problem after update
BOB Hello Friend, thank you for your excellent work, I'm having a problem with tv box MK808, after upgrading to 4.2.2 it will not let me turn on WI-FI, when I turn it sits on the home screen and deleting all the time I have no micro sd card installed, only the internal memory, but it does not work, you could help me with this problem?
Thankful.
André.
Is libstagefright supported?
I was unsure if libstagefright was supported in this rom or if we had to put it in separately. I saw the question was asked at the beginning of the thread but did not see a reply to it.
Also wanted to say thanks much for the hard work putting this together for us!
--X
It is not in the ROM nor will the libstagefright.so library released by Rockchip work on 4.2.2 kernel (3.0.36+).
Originally posted by Finless View PostIt is not in the ROM nor will the libstagefright.so library released by Rockchip work on 4.2.2 kernel (3.0.36+).
I purchased an MK808 last week and rooted it last night, flashed the libstagefright.so library and it seems to be working ok for the most part, just a few videos still have micro stutter, mostly panning shots. Xbmc, for some reason, plays some of the movies off my plex server fine while others are scrambled and reboot my MK808 so I try to use the plex android app as much as I can. I want to go to one of the finless roms but I'm trying to decide which one is going to be better for what I want to use my MK808 for, which is the streaming video, before I flash one.MK808
Finless 1.7c
2Dark4U 1.4 kernel
Lenovo N5901 wireless keyboard+trackball combo - currently looking for suitable replacement
There are currently 2515 users online. 2 members and 2513 guests.
