Penta WS708C RileyROM 1.0
    Re: Penta WS708C
    Our administrator, Neomode suggests you try his port of Android 4.2.2 for the rk29xx.
    Here is the link to the thread.
    If you just substitute your kernel with the one in the kit, it should work.
    Just read the thread...they have been working out some kinks...but it IS the latest Jelly Bean release.
    Sent from my M5 using Tapatalk 2
    Randy
      hello Randy,
      I think we have to replace
      etc/recovery.fstab in Ramdisk of cwm recovery...
      But CWM recovery.img extraction is not possible in my kitchen..
      It is saying that magic header is not found...
      Is there any different tool to extract cwm recovery.img..?
        One more thing..
        Today i tried ur beta rom...
        Tools provided for flashing are working...
        But after flash over my tab is not booting at all so i revert back to ur alpha rom which is working fine for me..
        I followed all the instruction in readme file but its not booting...
        One more thing i learned from BOB's post is to edit parameter file..
        And i manage to do this in ur alpha rom with 2gb for userdata & 768mb of system...
        And its working well...
        Link u provided is for 10" tablet right... Will this rom work for my 7" tab?
          In above thread there are many links...
          I mean i have to download Rom or Parameter & Loader or Rotation Fix via CWM or some thing else..
          Download link not working...
          It is saying This XML file does not appear to have any style information associated with it. The document tree is shown below.
          <tree><message type="SUCCESS"/><require_auth/></tree>
            Penta WS708C
            Yes, it is also a work in progress.
            Randy
            Randy
              Here's how to extract the CWM Recovery.img:
              From your working folder type:
              sudo dd if=recovery.img of=recoverycwm.img-ramdisk.gz skip=8 bs=1 count=20000000
              mkdir recoverycwm
              cd recoverycwm
              sudo gunzip < ../recoverycwm.img-ramdisk.gz | sudo cpio -i --make-directories
              Then you will have the files from the CWM version of Recovery.img
              After you're done copying/tweaking files recreate the file by doing this:
              sudo find . ! -name "." | sort | sudo cpio -oa -H newc | sudo gzip -n >../customrecovery.gz
              cd ..
              rkcrc -k customrecovery.gz customrecovery.img
              Now, that will be your new cwm recovery and you can flash that as your recovery.img
              I have tried unpacking, mounting, extracting with every tool known to mankind and this is the only way I have been able to extract the cwm recovery.img. Sorry, it took so long, because I couldn't remember exactly how I did it, so I had to try it first.
              Randy
                Sorry, wrong link...that one is old. Here is the new ROM:
                Randy
                  Ok...
                  I will try this method..
                  BTW i am using android kitchen tools made by xda-developers..
                  In this is kitchen they had provided very easy option to pack/repack boot.img & recovery.img..
                    Penta WS708C
                    Yep, but it didn't work for this particular file for some reason.
                    I learned how to do it manually, and prefer that route most of the time. Kitchens tend to put files where I don't want them, or can't find them.
                    Randy
                    Randy
                      R u sure that replacing only kernal in NEOCR ROM will work with my RK2928 tab..?
                      I will try this rom too...
                        Yes u r right... Ready made tools are not useful all the times...
                          Penta WS708C
                          It is worth a try, Neomode says it will. With stock kernel, this is made for rk29xx systems. He has it working on an Arnova Childpad. It is working on the Arnova 10bG3, also.
                          You may have screen resolution differences, so watch for that on boot screens, but those can be easily fixed.
                          I saved your stock boot animation. (it was cool). Holler if you need it.
                          Randy
                          Randy
                            I will definitely try...
                            i have to replace my stock kernal in boot.img & recovery.img of NEOCR ROM or simply replacing kernal in image folder is enough..?
                              Penta WS708C
                              Just replace his kernel with yours. That's all.
                              Randy
                              Randy
                                Thanks..
                                I will try...
