Penta WS708C RileyROM 1.0
Hello Randy...I found that CUBE U25GT has same RK2928 chip as i have...Is this possible that this ROM is compatible with me device..?Link: http://www.rockchipfirmware.com/site...4_20121227.zip
Today I Flashed CUBE U25GT rom from above link in my tab...Tab booted & system is loaded successfully... Problem is that this Rom is for 10inch tab And i have 7inch tab so it is not showing any button in android... And my hardware buttons are also not working...And in second try i replaced cube kernel into NEOCR rom and flashed.. Since my hardware buttons are not working with this kernel its not possible to get out of cwm recovery....Can we make something useful from above kernel..?
Penta WS708C
Looks like you are making some headway.
You should be able to get out of CWM by pressing the power button.
If you can edit build.prop you might try adjusting the screen resolution there.
RandyRandy
I put together another beta from scratch today. Partly because I'm wondering why it wouldn't boot.
This one is without CWM, since I can't test it. I took the kernel out of the recovery.img, so see if that works.
Also, I included the backup.img in the kit. I'm not sure what it does, but I left it out of the other ROM.
You have 2 kernels. The default is stock. The one named brandedkernel.img is one I put my brand on. I think the reason it wouldn't boot was I had the wrong resolution on the image I cooked into the kernel. See if it works for you this time.
Just go to the link on the first post of this thread.
Now, about Neomode's ROM. If you can open system.img, you might try putting in the SystemUI.apk and the framework-res.apk (in the framework directory) from the stock system. The screen resolution might be set in one of those files. If you can get 4.2.2 work...It's a whole lot better than ICS. If you want, I can put those in for you after I download Neomode's ROM.
It is typical for CWM to not mount everything on the first boot. When you get it to boot to system the first time, the SD formats...then try CWM by booting into recovery with the Reboot.apk. If it will work, it should work after a first complete boot.
So now you have choices. Let me know what happens.Randy
Here's one more thing to try:
This is the system.img for the Neomode 4.2.2 ROM with the dpi settings adjusted for a smaller screen. See if it works. Just replace the system.img with this file and flash.
To tweak it further, you can edit the build.prop. I read that the 800x480 screens default to 240 dpi.
Hopefully you can boot and see what your doing, in order to adjust the dpi setting to suit your needs.
Be careful, however, because this setting also reflects what apps you can get from the Google Play Store.Randy
Hi, Randy...
I am not saying that NEOCR rom worked for me but i am saying that CUBE U25GT rom worked for me and this rom is for 10inch tab and mine is 7inch thats why its not showing any buttons in system.....
And Extraction of backup.img is very much possible with
Link: https://docs.google.com/file/d/0B_id...NE0/edit?pli=1
Usage: rkunpack backup.img
In ur working folder...
Inside backup.img i have boot.img, recovery.img, misc.img, etc...
Today i flashed NEOCR rom with system.img u provided but it stucks at recovery as earlier happened with me...
OK, sounds good.
You might try editing build.prop in that Cube ROM. I set the dpi to 240 in the other one just because what I read, that is the default setting of 800x480 screens. Your stock ROM had the setting at 160, but they may have adjusted things in the kernel.
Otherwise, looks like your in the right direction with the Cube ROM. 900Supersport is your man for that one.
It has been fun trying to help sort things out for you.
At least, I got root on the stock ROM for you.Randy
You know what?
I just checked those links...for some reason you were getting my Yuandao N101 ROM instead of either of my two beta ROM's.
I fixed the links.
Either, or both of them might work now.Randy
Yep, no wonder they didn't work.Randy
There are currently 3197 users online. 1 members and 3196 guests.
