WHY? HOW? should I get XBMC on my MK808 & MK808B
    Originally posted by Sphinx View Post
    I've tested the xbmcandroid with mx player an it works well.
    At the moment i have a other problem with the xbmc versions from xbmcandroid and xbmc.org.
    I can't play any movie directly from the moviedatabase.
    Xbmc shows a dialog: working and crashes after a few seconds.
    If I select the movies directly with Videos->Files everything works fine.
    On windows everything works perfectly.
    Does anyone has an idea what problem it could be?
    for me its working perfect with external player . any issue that i can remark
      Ah mx player is only started for local files. It still uses the internal player for network files.
      - UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
      - MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
      - MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
        i m using mxplayer to, i dont have any issue streaming movies from the internet.
        i have not tested using files in my network. but i realy doubt that i shuld had any issue if the internet streming is working local network should work too.
          Do you think it could be a problem with the scrapingoptions?
          All covers and informations are shown in the database.
          Only the direct playback from the database will not work.
          I've tested it with the Finless 1.7 and 2.0 Rom.
          The files are on a directly connected usb hard drive.
            When playing local files it used MX player
            When playing from network (SMB) it uses the internal player
            When playing from an FTP server it says "External player active. Click oke when playback has ended". But there is nothing playing at all.
              xbmc context menu
              Installed Xbmc with Finless 1.7 . Really works great very stable watching many sports streams using sportsdevil plugin.
              I only have a remote mouse as my contoller. In order to activate context menu the Xbmc wiki calls the right mouse click however my right mouse click is programmed to go back to previous page/menu.
              What can be done to change right mouse button in order to open context menu?
              Steven
                Type c to bring up 'context menu'.
                  context menu
                  As I stated in my question I don't have keyboard connected only a wireless mouse!
                  Steven
                    Steven
                    I never used sportsdevil plug-in but if you have ">" on upper right hand side corner, context menu will show up by clicking it. If you use Navi-X it will work for sure.
                    GL
                      context menu
                      GL
                      Thanx for quick reply
                      I see the">" in Navi-x which brings up the context menu but in all other addons the ">" is non existent
                      So still hunting for a solution at the moment I use a usb keyboard.
                      Steven
                        Me too,how can we solve it?
                          font/text size
                          Is the only way of increasing the font/text size of XBMC (movie titles etc), changing the xml file, or is there an easier way of doing it?
                            I have a problem with XBMC XMF. My philips 47pfl6007 doesn`t play audio coded in dts. When i try to play any HD movie which has dts audio i got an error message "unsupported audio codec dts, try custom codec".
                            Any solutions?
                            edit:
                            I solved it. First i tried to change some things in xbmc audio setup but it didn`t work. I had to change codec in MX Player from H/W+ to H/W.
                              Originally posted by extremedmg View Post
                              Any solutions?
                              edit:
                              you can use hw+, you just need to install the dts custom codec for mx player:
                              install the arm for neon version. get the zip, unpack it, and go to decoder section in mx player scroll down to custom codec and point it to the folder you unzipped to.
                                media content problems..any help?
                                Can anyone help me on how to make my xbmc work with my media collections.
                                i have mk808 finless bob 1.7 720p kernel by 2dark4u. i have a powered 2tb external hard drive. with movies and tv shows. each movie(720p or less) and tv shows have thier scrapper, meta data (info and fanarts)already saved(exported) in thier folders individually from my laptops xbmc so xbmc android doesn't need to download fresh ones from the net. however. when i try to update movie and tv library..xbmc runs for a while and then freezes and i have to restart mk808 or it restarts by itself. so far, it has only been able to update 1300 movies out of about 2700. is there anything i am not doing right?
                                i love the meta data and fan arts etc been displayed with the movies..mxplayer and the lot dont seem to be able to do that. any help or advice or optional media player? i basically use my mk808 to play movies..i dont stream or use the ad-ons
                                thank you
