HOW TO ROOT POLAROID PMID705X?
I moved your post to the proper forum!
Originally posted by ysheila76 View PostJust bought it today at Big Lots and no surprise no google play store. How can I root my device?
See thread http://www.freaktab.com/showthread.p...0951#post40951 for rom
Originally posted by jtintle View PostI believe Elektrik has a custom rom for your device. I don't think it has been tested, but his roms come rooted and probably have Play store installed but he can tell you more.
Originally posted by elektrik View Postyep. it is a modified stock with the bloat removed. I made it at the request of someone who requested it previously but never provided any feedback. it may be completely fine-I don't know because I dpn't have the device but i'm pretty sure it will work
<tree><message type="SUCCESS"/><require_auth/></tree>
This is what it shows when I try to download your file.
Thank you for the help in advance.
Originally posted by ysheila76 View PostI couldn't download it, but I'm downloading the live suite image for flashing and after that I don't know what to do. I failed to mention that it is running jelly bean, 4.1.1. I've rooted the polaroid ptab7200 before with success with step by step instructions.If you could guide me the same way with this pmid705x, I think I'll be able to do it. This XML file does not appear to have any style information associated with it. The document tree is shown below.
also for live suit directions, follow these directions: http://southerntelecom.com/polaroids..._pmid705x.html
use whatever img you want. as for step by step, maybe E can help you out
Originally posted by jtintle View PostSorry I linked to the old download thread, try http://www.freak-tab.de/Elektrik/PMID705X.img
I tried to install the custom rom listed in this thread on my pmid705X. It didn't work out for me. When I was connecting my tablet to the computer, it was not recognizing it when I selected the IMG file for the custom rom. So I thought that I needed to factory reset the tablet before being able to install a custom rom (don't know why I thought that was the problem) and I loaded the IMG file that was on the support forum, and presto my tablet was recognized in the livesuite program, and I proceeded to flash the IMG file from polaroid. Well upon first boot I thought it looked a little different than the JB that was on it when it shipped, and I'll be now I am running ICS. I tried to go to system updates, but it keeps saying that I'm up to date. The weird thing is now I have full root, I only needed to download the superuser app from the market (I had no issues installing the android market, it actually went smoother than the stock JB)... so now I have root, but I do not have any more JB goodness. I tried to reconnect the tablet to the computer (for livesuite) and it is not recognized anymore... once connected it just gives a popup that says "OK" It's fine I guess being that I'm rooted I can do a lot more with it, but now I"m a little worried that I no longer have a way to flash anything onto it... Is there a different procedure for plugging it in with the ICS kernel on it? Maybe it has to been in a power on state now?
Re: HOW TO ROOT POLAROID PMID705X?
Originally posted by hootowlserenade View PostI tried to install the custom rom listed in this thread on my pmid705X. It didn't work out for me. When I was connecting my tablet to the computer, it was not recognizing it when I selected the IMG file for the custom rom. So I thought that I needed to factory reset the tablet before being able to install a custom rom (don't know why I thought that was the problem) and I loaded the IMG file that was on the support forum, and presto my tablet was recognized in the livesuite program, and I proceeded to flash the IMG file from polaroid. Well upon first boot I thought it looked a little different than the JB that was on it when it shipped, and I'll be now I am running ICS. I tried to go to system updates, but it keeps saying that I'm up to date. The weird thing is now I have full root, I only needed to download the superuser app from the market (I had no issues installing the android market, it actually went smoother than the stock JB)... so now I have root, but I do not have any more JB goodness. I tried to reconnect the tablet to the computer (for livesuite) and it is not recognized anymore... once connected it just gives a popup that says "OK" It's fine I guess being that I'm rooted I can do a lot more with it, but now I"m a little worried that I no longer have a way to flash anything onto it... Is there a different procedure for plugging it in with the ICS kernel on it? Maybe it has to been in a power on state now?
Sent from my 701c using Tapatalk 2
Originally posted by jtintle View PostWhen running the livesuit package, is your tablet is powered off, and disconnected from the computer? Then once you have the img selected try plugging the usb in while holding the menu button. You should hear a beep if it recognizes the tablet and should install the rom. At least that's how my 701c running ICS
With only 1 (very minor) change I got this to work for me on my PMID705X... when I downloaded elektrik's image I overwrote the one in the livesuite package (so that it had the same name, but was actually elektrik's image)... The only other problem I had was that I had to change the USB port I used (I have both 2.x and 3.x USB ports, not sure which is which)... After that it installed with no problems, and runs fantastically!
Thank you elektrik!
And before anyone asks: Yes, I did register just to say "Thank you"... elektrik deserves it
.. but because of this I will most likely be checking out this place every few days from now on
Originally posted by Jim1971 View PostOk, solved that last problem too, seems SuperSU that comes with the image is not working, but SuperUser (by ChainsDD on the market) does... All is puppies and rainbows with my tablet now
There are currently 1732 users online. 0 members and 1732 guests.
