Snapped from my Elektrik Polaroid PMID705X
HOW TO ROOT POLAROID PMID705X?
Re: HOW TO ROOT POLAROID PMID705X?
Originally posted by hootowlserenade View PostDid you install all of the drivers in the livesuit package? I have a windows7 64bit pc that I had to install the 32 bit drivers and put them in compatibility mode to get my tablet recognized properly. If you have teamviewer installed on your pc I can check your setup if you're not sure.
Originally posted by Briteyez83 View PostIm not sure. I have a lenovo T420 its 64bit. What is teamviewer?
It is a remote client for accessing your pc from another pc. If you install it (make sure to install it for personal use, as that is free.) you can send me a pm with the access code and password (it changes the password everytime you restart your computer, so no worries about anyone accessing without your permission) I have to go to work in 45 minutes though, so if you don't get setup with it until then I'll have to wait until I get off work.
Originally posted by elektrik View PostThat's cool and I'll definitely fix the SU, but for me to attempt to tweak a ROM without hardware I own, I want more than one tester-no offense intended.
Originally posted by elektrik View Postalrighty folks-try this one and provide me feedback.. If it works, I'll replace the experimental version I have posted
https://www.dropbox.com/s/hg64q26e4l...fied_stock.img
Originally posted by hootowlserenade View PostYes but I just tried it and can't get WiFi to connect... see if you have the same issue...
Sent from the cutting edge of my Droid RAZR MAXX
There are currently 3164 users online. 1 members and 3163 guests.
