Sent from the cutting edge of my Droid RAZR MAXX
HOW TO ROOT POLAROID PMID705X?
Re: HOW TO ROOT POLAROID PMID705X?
Originally posted by hootowlserenade View PostOK I got the WiFi to work... however I cannot get root access regardless of which superuser app I use... I've flashed the image 5 different times and its the same with each flash.
I'm just trying to update the su binary with any superuser app that's free in the play store.... when any app asked for root there was no popup to allow or deny access... tried a root checker app and it said not rooted
Originally posted by hootowlserenade View PostI'm just trying to update the su binary with any superuser app that's free in the play store.... when any app asked for root there was no popup to allow or deny access... tried a root checker app and it said not rooted
One way I know for sure is installing either Root explorer or es file explorer and setting the root option in there and see if it succeeds...
Originally posted by elektrik View PostWell the reason it wouldn't ask for root is because the stock SU binary doesn't ask for it. As for root checker saying it's not rooted, that would be a different story.
Originally posted by hootowlserenade View PostTitanium backup couldn't get root access either.
App data retention
So I have a question about data retention. If I move an app, say Angry Birds, to the "internal SD card", and then flash the rom to the Elektric rom, will I have still have access to Angry Birds and the save data, or will it all be gone?
Also, is the new rom JB?
Thanks,
Yoritomo
Originally posted by Yoritomo View PostSo I have a question about data retention. If I move an app, say Angry Birds, to the "internal SD card", and then flash the rom to the Elektric rom, will I have still have access to Angry Birds and the save data, or will it all be gone?
Thanks,
Yoritomo
1channel doesn't work once rooted?
Originally posted by hootowlserenade View PostJust checked out that website... it seems to be a PC orientated site that isn't android compatible... I will pm you a alternate site, let me know if it works for you.
Snapped from my Elektrik Polaroid PMID705X
Originally posted by Cloud222 View PostAre you serious? you can't stream off of 1channel.ch once you root ur device? what causes this to happen? is everyone having this problem? for me that's a definite dealbreaker, if I wont be able to stream from 1channel afterwards then there is no way I'm rooting my device :/
Originally posted by Briteyez83 View PostReally? Not gonna root cause of possibly not being able to stream 1channel? I was went on the site today to check it out and it wants you to update java, which is your flash player, in order to watch movies. Which version of android are you? Cause Java quit supporting android 4.0 and newer i believe cause ive had that issue with my D4. Just copy your working flash player from your phone to your computer then transfer via usb to your tablet. Use titanium to freeze or uninstall once rooted the current Java apk and use root explorer to open and install the working Java apk you transfered. Your flash player should work for 1channel....
Java (made bun Sun/Oracle) and Flash (made by Adobe) are two entirely different things.
Sent from my PMID705X using Tapatalk 2
There are currently 2121 users online. 1 members and 2120 guests.
