NEW- Measy U2C/B12 Finless ROM 1.7
    Originally posted by apache View Post
    By the way, I have an unanswered question:
    In case it fails to boot up after the ROM flashing, how could I reflash the ROM?
    Since when it fails both flashing tools fail to detect the device.
    You use the reset button! Hold it in and plug in USB. It will go into flash mode.
      AV-OUT
      IsewedMeasyU2cFinlessROM 1,7 andIcannotconnecttoitoldTV!
      AV-OUTdoesnotwork...
      bad mood...
        AV not working
        AV cable for measy is not the same as others. You need the proper measy AV cable or need to rewire. There is a thread at this link http://www.freaktab.com/showthread.p...Geekbuying-com. Did you get the AV cable with the measy or seperately?
          thankyou ! helped!
            antutu
            Just had 9300+ in antutu using the external SD. Mainly due to write speeds that were 25 times higher than the 7MB/s internal memory. External read speeds were 50 MB/s slower at 201 though. If write speeds are somehow of importance to anybody though an external SD could be the best option.
              Full HD (1080p)
              Hello! When will the firmware supports true 1080p?Finless ROM v1.7, as I know first encodes 1080 to 720, and then stretches the 720 back in 1080, losing the quality of Full HD
              Sorry for my poor english.
                When we get sources we can make a 1080 kernel. Until then it's not going to happen.
                  1080p on a dualcore need overclocking, better heatsink.. not sure its a good choice for these generation of android stick!
                  Maybe Bob will port an jb 4.22 rom when its available.
                  For now, Just enjoy this finless rom 1.7!
                    1080 kernel news
                    Well, you guys got me thinking.... I was able to patch a mk808B kernel to 1080P.
                    So I will do one for the Measy
                      Overclock
                      Yes probably good advice as I noticed there was no heatsink. Apparently an antutu overclocking and underclocking app uses automatic detection if the firmware supports it. I wondered really if anybody had success with overclocking. I will not take the risk preferring to leave it some other brave soul.
                        Kernel is locked and thus you cannot overclock.
                          Hi Bob, I would like to customise the images displayed before the boot animation(not the penguins). I know that these images are embedded in boot.img, but Android boot.img files are not the same, and opening them is not easy at all.
                          I wonder if you could let me know the app(s) used to customise this boot.img.
                          Cheers,
                            Bob juste made a 1080p kernel, give a feedback please
                              Portrait mode
                              hello ,
                              i have Measy U2C , I would like to know if there is a way to have an application in Portrait mode on screen TV , for example when I want to play Subway Surfer, i can not see the whole picture of this application, so is there a way to reduce the display of such application,
                              in other way , how to get portrait mode in landscape screen ?
                                Mmmm, flashed and stuck at boot animation...what can i do?
                                Just Reflash?
