NEW- Measy U2C/B12 Finless ROM 1.7
Works on Mk809II, and probably all the others with the same Wifi/BT Chip.
I have been using this forum for a while, but this is going to be my first post.
This rom worked on my Mk809II, and not just worked... it´s by far the best rom which i tested on my device. It´s better than 1.7a & 1.7b in my opinion.
Better performance, better Wifi ( ALOT BETTER), better kernel...
Is this Kernel from the original Rom??!
Thanks a lot , Bob. Keep the good work.
Yes, stock kernel.
USB to ethernet adapter
Hi, I am trying a USB to ethernet adapter with U2C.
It's recognized (Ethernet option turns on in Settings, and dmesg lists the model and drivers based on qf9700.ko)
But no connection, no ip adress.
When I connect the same ethernet cable to my Tv it gets ip and other parameters automatically.
Any hint is welcome.
Not sure but we do have some issues with some other thernet sticks where the drivers are there. This seems to be on all RK ROMs. They connect at 100Mbps and Android only supports 10.
See what dmesg says connect rate it or if your router shows 100.
Another thing you might try is setting a static IP. Some of these default to a Google public DNS of 8.8.8.8 which can be an issue.
Best guess I have based on issue with the 75xx series sticks as well.
Originally posted by Finless View PostNot sure but we do have some issues with some other thernet sticks where the drivers are there. This seems to be on all RK ROMs. They connect at 100Mbps and Android only supports 10.
Sorry for my very bad English! USB-LAN adapter, with RD9700 chip is only usb 1.1 on Android. For me, only the ASIX 88772A, and 88772B chipsets adapters given good speed.
..please help..
Originally posted by klikzord View PostI have been using this forum for a while, but this is going to be my first post.
Thank you in advance.
Originally posted by bobdeville View Post... I have now on my MK809ii the ROM 1.5 from Finless and I want to make an upgrade to "New Finless ROM 1.7 for Measy u2c /B12/ Imito V2 (rooted)", but the u2c have camera and the MK809ii doesn't have, so will not be a problem if I will flash that ROM on MK809ii?
Originally posted by s_benia View PostIsewedMeasyU2cFinlessROM 1,7 andIcannotconnecttoitoldTV!
AV-OUTdoesnotwork...
bad mood...
Originally posted by klikzord View Postno problem with that, I have the same device and i already did it.
The fact is only 720 and not 1080 is not a problem at all, i'm happy with 720 also, the only thing I want to know is if the resolution for icons can be increased from 160 to 210(?) because are .. big, so can be and how?
The games working very well, MKW's 1080 playing like a charm.
I doesn't test skype/tango/viber/yahoo mess yet but I hope to run well also.
I guess now the next step will be just the next android 4.2.
Thank you Finless for all !!!!!!!!
BR,
Originally posted by computaquark View PostAny ETA on 1080 kernel. Just asking in case I missed something somewhere.
It's a sticky post right below this one!
http://www.freaktab.com/showthread.p...l-in-the-HOUSE!
There are currently 1478 users online. 2 members and 1476 guests.
