No changes were made to the rom, just flashed on 100% genuine Meacy U2C :-(
NEW- Measy U2C/B12 Finless ROM 1.7
Ei guys, one question. I received yesterday my new Measy U2C and I want to install this awesome rom (I have it in other devices and it rules!!!). My U2C has Android 4.2.2 version so, as I read in this forum, I cant install CWM so I cant do a backup of the stock rom
Will this Finless ROM work in my Measy U2C?? Im afraid of having troubles with wifi, bluetooth or AV output like it happens in others RK3066 tvs because of the use of different chipsets.
Thanks!!
Originally posted by Wrongbloke View PostJust wanted to let people know that I figured out how to use the reset button to get it into flash mode and was able to flash the new rom. Works great now as far as I can tell.
On a related note, any plans to introduce a zooming feature?
can you help me for use a reset button to get in flash mode? I have a Ug802 dongle with a 809II v1.12 20130413 PBC
I have tried to use a reset pin 6&7 at NAND flash and other method but never.
Many thanks
Many thanks
Originally posted by lungomare View PostThe big photo of NAND chip.
I see there are many points. You can try one by one~Gopichand Pai
Originally posted by gopichandpai View PostTry what is mentioned here http://forum.xda-developers.com/show....php?t=2308980
My dongle don't have a micro USB at the side where the micro SD card slot as in photo at link http://forum.xda-developers.com/show....php?t=2308980
You have another idea?
I'm thinking even to solder a connector micro usb side as the mk809II
Originally posted by gopichandpai View PostSorry Mate. Not sure. I am a newbie.
Are you getting a right driver can't be found for your device or your device is not recognized at all?
The PC can not find the device. When I insert it you do not hear any sound. Among the usb devices is not there, even among the unknown.
I installed the driver but does not see it.
Originally posted by lungomare View PostThe PC can not find the device. When I insert it you do not hear any sound. Among the usb devices is not there, even among the unknown.
I installed the driver but does not see it.~Gopichand Pai
Just had an unexpected 11400+ in antutu. Trying to decide if this due to Antutu update or from moving user apps to external_sd. Anybody tested with latest antutu with apps on internal ROM? Way above the 7000 +/_ I used to get at 1080p
Originally posted by computaquark View PostHave the ROM installed and it seems too boot and respond just fine. Speed in synthetic benchmarks about the same as 1.4 ROM. Best run 9200+ that was slightly higher than the 9100+ in the 1.4 ROM. First run in Antutu was only 7500+ and I thought Bob had blown this one but a few reboots eventually got the benchmarks above 9000. It seemed the first run in Antutu was always a little slow as the device needs to get warm.
On the surface this ROM appears similiar to the previous as any stability and compatability fixes are not immediately visible. Sleep is a useful addition even if not what I had expected. I had envisaged a sleep option in the reboot menu but that was obviously my misconception. Using restore software I soon had all my programs and system data from the 1.4 ROM reinstalled without any compatibility issues arising.
Thanks again Bob
Originally posted by computaquark View PostTry making sure you are using OTG that is on the side of the measy and not the end opposite from its HDMI connector. Click the reset then plug into computer before releasing reset.
I don't have a OTG on the side. I have only micro usb and usb at the end opposite from the HDMI connector.
Can you see the image
Have you another idea?
OTG
does not look like a measy u2c. Is the camera on the other side? As far as I know OTG is the only way to flash. Is there a hole in the plastic housing where the OTG should be? If there is then the OTG connector may have broken away. Could try going through the full sized USB connector next to the HDMI. Or maybe try an HDMI hook up.
Originally posted by computaquark View Postdoes not look like a measy u2c. Is the camera on the other side? As far as I know OTG is the only way to flash. Is there a hole in the plastic housing where the OTG should be? If there is then the OTG connector may have broken away. Could try going through the full sized USB connector next to the HDMI. Or maybe try an HDMI hook up.
Hi, my model is 809II as a photo.
The OTG port is missing, not soldered from factory and I don't have camera or hole for OTG port.
I have try full USB but never, the pc don't see the dongle and I don't flash it :-(
There are currently 1422 users online. 3 members and 1419 guests.
