Better WiFi!
Originally posted by hitman72 View PostREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Ok i made some zips for you.
fratello 2 zips for you, you must install from cwm recovery, like allways I suggest to make a backup of your actual rom with cwm before install this:
First lets flash the boot.img with this zip:http://cloud.freak-tab.de/public.php...333fd93801136f(this zip must work for mk808finless rom 1.7c and mk808b finless rom 1.7)
After install from cwm recovery this file too, with it we will install the module and a script in init.d so it will load in each boot:http://cloud.freak-tab.de/public.php...b4391b7af6dc3a(this script must work for all devices that uses init.d support)
Please tell me if your wifi donge works with it
For you hitman72, I cant find my kernel.zip so I made a new one, flash it from cwm recovery, inside is a empty kernel.img, you only need to open it with winrar or 7zip(only open dont extract) and drag&drop inside the kernel you want to use:http://cloud.freak-tab.de/public.php...510eb25f1b4905 DONT USE THIS ZIP DIRECTLY, INSIDE IS A EMPTY KERNEL.IMGREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Thanks You so much for this hard work !
... I apologize for being so silly, but I don't know anything about cwm and how " install from cwm recovery this file too"...It's somewhere a tutorial about how to do this ?! Can You build a ROM, ready for flashing in "classic" mode ?!
Thanks and forgive me ...
cwm recovery is very easy to install, and you can use it to flash roms without the pc and to make backups of your current rom. I really suggest everyone install it, cause if you get a nand corruption or boot fails is a easy way to restore the device to a working state (will all your apks installed) in less of 5 minutes.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
ok, just to say all works fine with 720p kernel, eyes rest, all is much smoth (expecially "go launcher hd") and I have gained up to 15 fps in some games. but the most important thing for me is that 8712u.ko works still great. thank you a lot leolasIo ho 41 anni. Ho fatto tante cose, tante cose. Cose... cose di ogni genere. E una verità l'ho scoperta. Una sola verità. Sì una sola. Vuoi sapere qual'è? Ho scoperto che sono un porco bastardo. (tokyo decadence)
Re: Better WiFi!
Originally posted by hitman72 View Postok, just to say all works fine with 720p kernel, eyes rest, all is much smoth (expecially "go launcher hd") and I have gained up to 15 fps in some games. but the most important thing for me is that 8712u.ko works still great. thank you a lot leolasnice
OK, later today (after work) I will try to "upgrade" to an working USB WiFi ...
So :
-first step = installing CWM from here : http://androtab.info/clockworkmod/rockchip/rk3066/
-then put file "boot_with8712u_support.zip" on SD-card, reboot in recovery mode (apk made by Petrus - must installed or is in Mr.Finless ROM ?), install this zip file ;
-after that, put file "8712u_wifi_suport.zip" on SD-card, re-reboot in recovery mode, install this zip too
-restart in "normal mode" and the USB wifi stick must be available for use.
It's OK ?!
Re: Better WiFi!
Originally posted by fratello View PostOK, later today (after work) I will try to "upgrade" to an working USB WiFi ...
So :
It's OK ?!
Copy 2 files to sdcard or external sdcard
Install both in the order I gave you in the post abobe.
Restart and you must have WiFi.
If something is wrong you restore your backup and everything goes back to the state you was before the zips was installedREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Thank You !
You say "Is vey simple, if you are in the stock firmware or any stock rom based in only need to rename cwm.zip to update.zip and copy it to our sdcard, the system will boot and tell us that it find an update, answer yes to install it. The original restore image will be backup in our sd, and the new one will be installed."
Why do I need to "Fitst make a backup of your current Rom. Very important!'" ?!?
Re: Better WiFi!
The procces must work, but I don't have exactly your stick(mine is the b version) and I don't have exactly your WiFi dongle.
Is a security option, with a backup made you have nothing to fear.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I installed CWM ... with Finless ROM Flash Tool (as in picture from first post). All ok, the device boot normaly.
I choose to "reboot to recovery" ...and I wait for about 10 minutes ...Screen is black ; blue LED ON ; but nothing happens... If I turn power off I brick my device ?!
Later edit.
Yes, he was bricked... So, I re-flashed (Fortunately successfully !) with Finless 1.7c.
Any -new- suggestion ?!Last edited by fratello; 08 May 2013, 13:38.
Re: Better WiFi!
Originally posted by fratello View PostI installed CWM ... with Finless ROM Flash Tool (as in picture from first post). All ok, the device boot normaly.
Later edit.
Any -new- suggestion ?!you have mk808 original right?
And you downloaded from freaktab the zip for mk808.
I will explain it step by step.
Now you have Finless rom 1.7c for mk808 installed. Lets start from this point.
Take a microsd card, and copy inside the zip you download from androtab. Rename it to update.zip and insert it to the device..
Android will ask you that a update is found and if you want to apply it.
Push yes.
The system will reboot and install the zip, don't touch it untill the sticks reboot in cwm recovery.
Now arrow down untill backup and restore. Now you must choose backup to sdcard or external sdcard, I prefer external sdcard cause if you have a problem with the stick you will have a working backup in the external sd.
Wait untill the backup finish. And reboot.
Now copy to your sdcard the 2 zip I gave you.
Now select install zip from sdcard.
Install both files.
Reboot.
Now your WiFi dongle must work. If you have any problem ask.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
because here they are very friendly with us "noobs", expecially leolas :-) I will try to help if possible. with ug007 to install cwm I downloaded the appropriate zip, moved it to root of internal sd, renamed in "updated.zip" and rebooted the android stick. at the reboot, android sees "update.zip" and asks to make the update, just tell yes, and after another reboot you have cwm installed. ciao :-) I think that this method works with all rk3066 devices. ciao :-)
edit: came before leolas, sorry
Later edit.
Any -new- suggestion ?!Io ho 41 anni. Ho fatto tante cose, tante cose. Cose... cose di ogni genere. E una verità l'ho scoperta. Una sola verità. Sì una sola. Vuoi sapere qual'è? Ho scoperto che sono un porco bastardo. (tokyo decadence)
You have mk808 original right? RIGHT !
And you downloaded from freaktab the zip for mk808. YES !
Take a microsd card, and copy inside the zip you download from androtab. Rename it to update.zip and insert it to the device.. OK !
Android will ask you that a update is found and if you want to apply it. NO !!!
I have this image on screen :
try to move the zip into "internal storage" with and android file manager
I have this image on screen : [ATTACH=CONFIG]2157[/ATTACH]Io ho 41 anni. Ho fatto tante cose, tante cose. Cose... cose di ogni genere. E una verità l'ho scoperta. Una sola verità. Sì una sola. Vuoi sapere qual'è? Ho scoperto che sono un porco bastardo. (tokyo decadence)
There are currently 2203 users online. 0 members and 2203 guests.
