Better WiFi!
Re: Better WiFi!
Originally posted by fratello View PostREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I tried again...inserting the SD-card with update.zip WHILE the stick was ON. Upgrade detected, say "Yes", re-boot, same injured Android...
I copied the update.zip into root of internal. Open file explorer, update detected, say "Yes", re-boot, Android with same animation in "stomach" but soon all stop, blue screen ... I expected about 5 minutes
...no sign of life, so I re-flashed ( so well it worked !) with 1.7c.
I think it's something wrong with my MK808, don`t ?!
So...for now I stop here, I`m afraid to spoil the device ...
Thanks again for hard work and patience !
Re: Better WiFi!
Originally posted by fratello View PostI tried again...inserting the SD-card with update.zip WHILE the stick was ON. Upgrade detected, say "Yes", re-boot, same injured Android...
The last try, lets see if this update.zip works. Download it and copy it to sdcard, accept the install and cross the finguers.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Re: Better WiFi!
Originally posted by fratello View PostThanks ! I will try this version tomorrow ...now I have no more access to any device (my little boy is ready to sleep).
Question : maybe it's better to "downgrade" to Finless 1.6 or 1.5 ROM ?!?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I'm back !
Installed cwm ... with some errors (? illegible because of displaying wrong...). Made backup on SD-card (FAT32 formatted). Re-boot - but stuck on boot, with Finless 1.7 screen ...
Rebooted (with switch pressed) to cwm, restore from SD-card, all OK !
Erasing update.zip from SD-card, copied "boot_with8712u_support.zip" to SD-card (without changing name of file).
Reboot in recovery mode, tried to install zip from sdcard - no success ; tried to mount external_sd - no success ! Attached results of log ...
Now ?!?
Now ?!?Your external sdcard is formated in fat32 and it is not recognized by cwm? sure that is in fat32 and not in ntfs?
Well at least we have cwm installed now and we get a functional backup, right?
well lets do it step by step
reboot and enter to Finless rom.
If it fails and get a bootloop tell me.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by fratello View PostThe stick boot OK into Finless ROM ; I tried for couple of times ...
I tried to install the two files with two SD cards different, sure FAT32 ...
Note : I was able to restore from SD card, so ?!? Why can not install other files ?!?
LOL
I think that I sent you the mk808b cwm zip
instead of mk808 zip
and I am searching for the mk808.zip and i cant find it
Have you a lot of things installed? Please lets speak in pm i will send 1 to you.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Thanks to Leolas - whom I thank for putting up with me - I have a wifi dongle adapter that works correctly TP-Link-WN723N. Unfortunately, the reception is -at least- as bad as the internal antenna ...So I have not solved anything by purchasing this adapter!
I have to make a last attempt : Biquad Antenna (http://martybugs.net/wireless/biquad/) !
Thanks again Mr.Leolas for your kindness !
Originally posted by fratello View PostThanks to Leolas - whom I thank for putting up with me - I have a wifi dongle adapter that works correctly TP-Link-WN723N. Unfortunately, the reception is -at least- as bad as the internal antenna ...So I have not solved anything by purchasing this adapter!
Thanks again Mr.Leolas for your kindness !REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
hallo, i have a rtl8188cu and i tried a driver for a rtl8192cu. after the replacement of the rkwifi.ko file, the wifi adapter blinks its led every 5 second (not as when is plugged into the pc) but it doesn't show me any connection. Maybe is it the wrong driver? i tried several drivers but this is the only that appears to work... anyone has this chipset?
thx
edit: problem solved. flashing the finless 1.7a the wifi usb worksLast edited by eRommel; 01 June 2013, 11:45.
There are currently 3490 users online. 0 members and 3490 guests.
