External HDD, is it possible?
Originally posted by Horrorzilla View PostUse a poewred USB hub and should have no problem. I use a WD 600GB externsl HDD for movies and have no problems. It is formatted as ntsf - so I can transfer files larger than 4GB.
Leolas in earlier post mentioned mk808 is 'picky' on the powered hub.
guess that the problem i am having.
So Leolas, can you share with us the brand, model and type of hubs that worked.
Re: External HDD, is it possible?
I have 3 usb hub, all 4 ports, and only one of them branded like conceptronic, the other 2 not branded. Latter I will post the exact name, but it is old and dont know if you can find it.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 1632 users online. 0 members and 1632 guests.
