Want to try to compile drivers for you? Come here and I will try to do that. RK3066 devices
    Originally posted by leolas View Post
    Good It works, be sure in your old tv that you use the correct resolution, have it a standard 720 or 1080
    I have upgrade the firmware of my tv and i did a factory reset now it works with my old tv too
    The version i use of the driver is the 1080 and it works perfectly with the finless 1.4 4.1.1 for the t428 i only needed to set my sixaxis orientation to -90 degres and the virtual_touchscreen is perfect i am surprise to see how precise the buttons and axis are.
    I use the 1080 virtual_touscreen driver with a 720p rom but my resolution is upscale to 1920*1080p (yes my tv is old but it was one of the first to support 1080p)and i am very happy .
    You are a hero!
    Hail to Leolas ! Great work man!
      Re: Want to try to compile drivers for you? Come here and I will try to do that. RK3066 devices
      Thanks for your report, it will help some people
      My devices:
      Gearbest.com)
        Can you please help compile drivers for RTL8187L? I have a MK808 which is running on ROM finless 2.1. I am a green hand in Linux, but the wifi in MK808 is really bad, I had a RTL8187L wireless adaptor, I need the driver for it.
        Thank you~
          I am in home now, sorry but today can´t make any compilations tomowwow i will start to try to compiling some drivers.
          My devices:
          Gearbest.com)
            Originally posted by kennythewise View Post
            It works with the new kernell 3.0.36+ on my t428 thx a lot
            But only on my new tv with the tv in my room it does not work but i think it is a EDID problem my tv is old(2008) panasonic lcd Tc37lz85 and sixaxis does not reconize the resolution of my tv in touch emulation the result is 255 0 255 0 is there a way to bypass the edid?
            Finally my tv was not the problem i found the real culprit and it was my usb hub. If i boot my t428 with my usb hub the virtual_touchscreen driver will not work i get 0 255 0 255 from sixaxis in touch emulation. If i boot the t428 without my hub no usb connected then the touchscreen driver will load and works fine with sixaxis i think it could be a conflict with another driver that shares the same ressources. When my t428 has booted and i am on the desktop i connect my hub back and everything is working fine my usb devices and my virtual_touchscreen driver aswell. I know that many people had the same problem with the 3.0.8 kernell so perhaps i found the solution for them
              Good, this could help.
              leolas
              My devices:
              Gearbest.com)
                Thank you~
                i've already ask that rtl8187l for my alfa to leolas too. hope it work
                  @robert, your driver is taking so much time, i will not forget it, and i will try it but i will to compile some others driver while.
                  My devices:
                  Gearbest.com)
                    Originally posted by yurkomik View Post
                    Hello our hero. I googled allot and can't find ftdi_sio.ko and cdc-acm.ko modules for new kernel. I found it for 3.0.8+ but there no such modules for 3.0.36+ I do not know how do downgrade my firmware on my stick. Please help if you can!
                    Thank you!
                    I sent you a PM.
                    here are those driver if some one want to use them:
                    PD: yurkomic reports it works in a PM
                    My devices:
                    Gearbest.com)
                      Originally posted by PMisYMMV View Post
                      Can you please help compile drivers for Zonet ZEW2545 USB wirless adapter?
                      I tried to attach the linux driver file to this message, but it wont let me. I downloaded it from here after entering random name and email address.
                      Thank you so much ahead of time. Please help me if there are instructions for this not-so-savvy user.
                      This one was a really hard to do one, cause it is designed for 2.6.x kernels and some functions change in 3.0.x kernels, after a google deep search, I found that "usb_buffer_alloc" and "usb_buffer_free" must be changed to "usb_alloc_coherent" and "usb_free_coherent"; so i need to search in all this driver sources those functions and substitute them :P
                      You didn't say to me what is your current kernel 3.0.8 or 3.0.36.
                      Here is the module for 3.0.36:http://cloud.freak-tab.de/public.php...02cf9769dfbb4d
                      If you need it for 3.0.8 say to me and I will compile it for that kernel.
                      My devices:
                      Gearbest.com)
                        Thank you~
                        Here they are, great headache cause i didnt find drivers for this device, finally I found them in the realtek site, some dependencies resolved and some functions fixed too
                        But finally I think I got it
                        Please, like always report if it works or not. It can help the others users who search for this drivers and me, cause without report I don't know if the driver works or not.
                        3.0.36+ module:http://cloud.freak-tab.de/public.php...e3daf097a40456
                        and http://cloud.freak-tab.de/public.php...79d4fef03754bd
                        I think you need both modules to make the dongle work, please report if it works or not
                        If you want the 3.0.8 version wait a little, i need to install the 3.0.8 kernel sources and install 3.0.8 rom in the stick
                        My devices:
                        Gearbest.com)
                          Really appreciate ur hard work and support on it. I insmod it, turn down wifi and bring it on, still not working, can any solution for me to check if the 8187 wireless has been plugin or it just anything else missed?
                          thanks for compiling anyway.
                            I will try to explain step by step.
                            First disconnect internal wifi in settings and reboot
                            don't connect the wifi dongle yet.
                            Open terminal emulator
                            write:
                            insmod /your/driver/path/r8187l.ko
                            now connect your dongle.
                            write in terminal
                            iwconfig
                            dmesg
                            tell me what it said. In dmesg only the last lines are neccesary.
                            My devices:
                            Gearbest.com)
                              write:
                              write in terminal
                              iwconfig
                              dmesg
                              iwconfig gives me three 'NO'
                              1.txt
                              dmesg gives a lot of information, i upload it, and let u make it out. the txt is here 1.txt
                              1.txt
                              thx1.txt
                                [ATTACH=CONFIG]2281[/ATTACH]
                                dmesg gives a lot of information, i upload it, and let u make it out. the txt is here [ATTACH=CONFIG]2281[/ATTACH]
                                thx[ATTACH=CONFIG]2281[/ATTACH]
                                Code:
                                <6>[   84.298800] rtl8187L: Initializing module
                                <6>[   84.302849] rtl8187L: Wireless extensions version 22
                                <6>[   84.307858] rtl8187L: Initializing proc filesystem
                                <6>[   84.313275] usbcore: registered new interface driver rtl8187L
                                <6>[  126.890496] usb 1-1: new high speed USB device number 2 using usb20_otg
                                <6>[  127.107408] usb 1-1: New USB device found, idVendor=0bda, idProduct=8187
                                <6>[  127.107559] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                <6>[  127.107670] usb 1-1: Product: RTL8187_Wireless
                                <6>[  127.107743] usb 1-1: Manufacturer: Manufacturer_Realtek_RTL8187_
                                <6>[  127.107833] usb 1-1: SerialNumber: 000F04B02556
                                <6>[  127.114235] rtl8187L: Reported EEPROM chip is a 93c46 (1Kbit)
                                <6>[  127.128629] rtl8187L: No channels, aborting
                                <6>[  127.128657] rtl8187L: Initialization failed
                                <6>[  127.128933] rtl8187L: wlan driver load failed
                                Wait a sec i think tou need a module for the eeprom chip wait 5 minutes.
                                Compiling it i will send you it in a few minutes.
                                Ok compiled. The link is :http://cloud.freak-tab.de/public.php...79d4fef03754bd
                                Lets repeat the steps before, but now insmod first the eeprom ko then the r8187l.ko moule; then connect the dongle and then iwconfig and dmesg.
                                My devices:
                                Gearbest.com)
