OLD - Minix Neo X5 Finless Custom ROM 1.2b
    I have not tried it yet myself. I will look into it.
    Go into settings accounts and make sure it is set for your account. All sync-able things are in there and it maybe unchecked by default.. There will be progress sync icons that will show you what is happening.
    Hello again, I have made a new clean installation of the ROM and the problem persists: synchronization failure google account in settings and install Google Calendar does not work.This account I have on other devices andoids and I have that problem. You think you can fix this problem?
    thanks
    oceanon3d
      I will look into it. Going on a little vacation tomorrow so I wont be able to do it till next week.
      I question if the stock ROM this was made from has the same issue? I bet it does. Nothing I did should have broken calendar sync.
        Bob! You are Great!
        I'm downloading and will install shortly. As you rightly said "NEO X5" is one of the very few good devices available in the market with good hardware + ports + connectivity + OS support.
          Hello,
          first of all: Great Work, thx!
          ROM 12a 720air is a little bit slower in Antutu as original.
          Why?
          R.
            It should not be at all but remember you always get some variability in antutu scores. Thus run it a few times to get an average.
              Thank you very much Bob!
                Hi Bob,
                I haven't installed your latest rom yet. I'll surely do it in the coming days!
                Nevertheless, I am taking the opportunity to thank you once more :-) This is so great having a dev like you pushing our devices to the edge.
                Keep up the excellent work.
                Greetings from Belgium ;-)
                  Working Fine!
                  I have installed 1080p version and everything is working fine. Keep up the good work.
                    AW: NEW - Minix Neo X5 Finless Custom ROM 1.2
                    Correct. 10500 now.
                    Gesendet von meinem Galaxy Nexus mit Tapatalk 2
                      Re: NEW - Minix Neo X5 Finless Custom ROM 1.2
                      Bob are you uploading 1.2b with the touchscreen fix with all files installed already.
                      Sent from my SGH-I717 using Tapatalk 2
                        Yes it will be up in about 30 minutes. Except it will only be the Joy Center fix. I am not adding the touch screen module to the ROM until I know more about it and it is tested more. I don't want stability issues.
                        Until then use this post to install the touch screen driver.
                        I have removed 1.2a download.
                          1.2b is up!
                          UPDATE 4/6/2013!
                          OK so it was shown to me the Joy Center APP was not working.
                          Stock ROM was missing USB Host permissions and thus my ROM was too.
                          This is now fixed.
                          And YES libstagefright patch is in 1.2b
                          This is now called 1.2b download. If you have 1.2 or 1.2a you should download 1.2b and reflash. However to not erase your APPs and stuff, just flash system.img and you should be fine.
                          The new download is in the first post of this thread!
                            THANKS !
                            I want immediatly try Your ROMs!
                            Thank you BoB!
                            G
                              Well I tested with 1.2, 1.2a and the latest official ROM and all give me the same problem: in settings not synchronize my google account (Gmail accounts in settings is red) well my email receipt Gamail but if I install Google Calendar and synchronizes the application fails ... create another Gmail account and more of the same. Could you find a solution?
                              thanks
                                Re: NEW - UPDATED - Minix Neo X5 Finless Custom ROM 1.2b
                                UPDATE 4/6/2013!
                                This is now fixed.
                                How do I flash just the system.img
