CX803 II RIleyROM v1.0
"fn" button
Originally posted by rrileypm View PostA few people have requested this, so in Bob absence I put together a ROM for this device.
This ROM includes:
Root
2gig user app space
Google Play Store fix
Init.d support if you need it.
All the other bells and whistles that Bob includes will come later.
I tested Netflix with an old copy I had from a backup, but it didn't work. I downloaded the latest version from Google Play Store and it works fine. Wifi works great. I really like the external antenna, what a great idea. I did not test bluetooth, as I don't have any bluetooth peripherals.
I found that you can get into flash mode easily by holding down the "fn" button while inserting the usb plug. It has worked for me every time. Wait about 10 seconds before erasing idb, because the two devices need a little time to start communicating.
There is the link to the download thread:
Post here with any comments or suggestions. This is my first TV stick ROM...so please be nice........
Thanks to Tattman65 for his usually fantastic boot graphics.
Thanks to Finless for buying the stick for me.
Thanks to Geekbuying.com for supplying the stock firmware and shipping this thing out to me in record time.
You must install this rom using the flash tool in the kit. It has to run from a Windows pc.
RandyRandy
Originally posted by rrileypm View PostYou must install this rom using the flash tool in the kit. It has to run from a Windows pc.
Randy
I am new to this TV stick and I never flashed a rom before. Can you point me where I can get the tool kit to flash the rom and also instructions on how to do it?
Thanks,
Just follow the download link in post #1. Follow the instructions there and in the readme file within the kit.
RandyRandy
Oops. Sorry.
Some quick tips.
1. Install the driver included in the kit manually.
2. Make sure you turn USB debugging off.
3. Get into flash mode by following directions in post #1.
4. Erase IDB from the flash tool.
5. Flash the Rom.
RandyRandy
Originally posted by rrileypm View PostOops. Sorry.
Some quick tips.
5. Flash the Rom.
Randy
2. Where do you turn off USB debugging?
3. How do you get into flash mode? Press and hold the "Fn" button?
Thanks,
Oliver
Go to settings and scroll down to developer settings and make sure USB debugging is unchecked.
Hook up your device to your pc. Stop the automatic driver install and bring up device manager. Find the unknown device and manually install the driver from the drivers folder in the kit for your version of Windows.
With the flash tool open you should have "found mass storage device". Do what I said in post #1 to get into flash mode. Wait about 10 seconds.
Click erase IDB. Let it finish. It will tell you.
Click flash rom.
When it finishes your device will reboot. First boot takes a while. Wait for everything to load then reboot one more time before adding accounts and installing apps.
Then you should be done.
RandyRandy
Originally posted by rrileypm View PostGo to settings and scroll down to developer settings and make sure USB debugging is unchecked.
Click flash rom.
Randy
Click flash rom.
Randy
Do you need to connect the HDMI cable to the TV to flash this ROM? Can I just connect to the PC only?
Since my PC is across the room from my TV, the only times I have flashed mine have been without being hooked up to hdmi. I just follow the prompts on the flash tool. Just give it time to boot the first time before you disconnect.
I'm sure the better way would be for me to purchase a DVI adapter and watch what's happening on my PC monitor, but I haven't done that yet.Randy
Originally posted by rrileypm View PostSince my PC is across the room from my TV, the only times I have flashed mine have been without being hooked up to hdmi. I just follow the prompts on the flash tool. Just give it time to boot the first time before you disconnect.
Does this ROM work on PS3 controller or XBOX360 controller?
Sorry, I didn't add any drivers to this ROM for external devices.
Hopefully we can do a whole revamp of this ROM soon with more bells and whistles.Randy
There are currently 2399 users online. 1 members and 2398 guests.
