UGOOS UT2/UM2 and UT1 official firmwaries
    I discovered some bugs which need to be fixed:
    1. USB OTG (On-The-Go) does not work. I tested it with 3 OTG cables and 4 USB drives. None of them are detected on the OTG port (but on the normal ports). It works with the wasser-ROM 1.0.4 for the K-R42 (new revision)
    2. The USB-Debugging (ADB) mode does not work. I tested it with 3 different cables under Windows 8.1 and Windows 7. "Connect to PC" and "USB Debugging" was activated. This mode is necessary for rooting. Also works with other ROMs
    And since there is always some room for improvement:
    1. Please add a Power Menu for Standby, Shutdown and Reboot.
    2. Make Nova the default launcher.
      Sorry what we cant help to you with this problem yesterday. I every day using adb on linux without problem. And now i checked on windows 7. All working. Please try install drivers from here: link . In this archive you can find drivers for adb also... in folder "ADB drivers"
      Today will be release firmware v 1.1.1. with Power menu and root.
      Official Ugoos firmwares with linux you can find here.
      Official Ugoos firmwares for UT2/UM2 and UT1 you can find here.
      Sorry for my english XD
        Will the factory remote control commands be fixed in this release? How about the static IP bug?
        See post #3 and #6 in this thread...
        FLHT = Harley
        HEMI = 2010 Dodge Challenger SRT
        Cause I've been asked.
          Unfortunately, the link you provided is not online anymore. Where will the new firmware 1.1.1 be released? Fortunately, I solved the bluetooth problem last night:
          http://freaktab.com/forum/tv-player-...203#post498203
          I would like to test it with the new firmware, but the bluetooth section must be visible for this. Please send me a link.
            Bug with static IP was fixed but not included in 1.1.1, sorry please wait 1.1.2.
            Yes, IR remotes buttons was remapped.
            Sorry, i dont know why link is broken.. Please try from here: link
            Thanks for you solution, may be i will integrate this in the next version of firmware.
            Originally posted by Beonico View Post
            I get this logo on the screen. I have the 8GB version. In the meantime, I'm back to the Wasser rom.
            Sorry for the inconvenience of the past. Please try using new firmware... I think problem was solved.
            For me is very important your review.
            News about release new firmware here -> link
            first post was update..
              Update OTA from V1.10 to V1.1.1 - Not working for me.
              1) Tried checking for updates with Rockchip System Updates menu option - no joy
              2) Tried with System Updates - no joy
              3) Tried with auto Update On in Rockchip System Updates - no joy
              4) Shut down and powered up with Auto Check Update ON in Rockchip System Updates - no joy
              Is there a way to force an update from SDcard?
              FLHT = Harley
                OTA updates will be available tomorrow. Now they switched off.
                  Thank you for the new link. Is the bluetooth section in settings visible/available? Otherwise I can't add the bluetooth function.
                    No, in 1.1.1 Bluetooth settings hidden on UT1 . You solved your problem with adb?
                    Now OTA Updates available for download.
                    We know about wrong size value of the package in the message about new available updates. It is not critical bug, and this mistake on our server. Dont worry about this. Updates should installed without any problems.
                    Size of OTA package from 1.1.0 to 1.1.1 ~90 mb.
                    Size of OTA package from 1.0.0 to 1.1.1 ~460 mb.
                    Thanks for all the help in creating firmware!
                      Ava, Thanx !!. Now I was able to install V1.1.1 on my Ugoos UT1 and it works.
                      The system information in the system bar and the power menu is handy.
                      The comming days I will check the stability with other app's.
                      Thanks for the good job.
                        I could try and flash the firmware for the UT2 and reflash the Kernel for the UT1. Could you post a link including the new kernel from version 1.1.1.? I will test ADB afterwards.
                          This morning I took the OTA from v1.1.0 to V1.1.1. Update was very quick and problem free. Great job! My UT2 finally has a working remote control again!! The extra option of obtaining root works very well. I choose "Silent Mode" and now have root. Easy one click root! I have two UT2 boxes. One of them came to me with the RK3188T chip. This is the box I have installed the V1.1.1 FW on and it works fine so far on it. So now I will update the other UT2 with V1.1.1. Incidentally, mapping the BLUE button to start Kodi was a brilliant idea!
                          Thanks so much for finally giving some attention to the UT2! Looking forward to V1.1.2 with fixed static IP!
                          LX+R
                          I don't answer PMs about things that should be asked/answered out in the forums. Not trying to be mean about it but I think the question you PMed me might interest and be of benefit to others here as well.
                          With that said, you asked me if Bluetooth options are available in V1.1.1. Yes they are! I just paired a BT speaker to the UT2 and it worked. Sound is ~slightly delayed but not bad. In Kodi you could adjust the delay and be fine IF it bothered you.
                          FLHT = Harley
                            You got the wrong end of the stick, pal. I own a UGOOS UT1 which doesn't have a built-in bluetooth chipset. The last 2 years I tried to find a solution with an external usb bluetooth dongle, which finally worked 2 nights ago (There is a seperate thread for this) I just asked this question to decide whether I flash the new firmware 1.1.1 because this "add-on" only works with bluetooth visible in the settinsg menu. I think I'll take a pass on this one and wait for version 1.1.2 where hopefully the bluetooth menu is unhidden.
                              I knew what you have (UT1)....YOU asked this question of me :"Is the bluetooth section available in the new firmware 1.1.1? ".
                              I gave you the answer....now you hold the other end of the stick for a while I'm tired!
                              FLHT = Harley
                                Thank you!!! I´ve installed OTA (first try fails, I think due to all modifications I do in 1.1.0, but after a new flash of 1.1.0 OTA works great) and now reconfiguring my apps. Until now everything looks great. Just after install screen was flicking, but after a time it appears to stop.
                                Good job!
