No way in the app manager to disable it but I did force stop it and the errors from the PS3 stopped until it started running on the UT2 again....this is a real problem as I have 2 UT2s and these error messages from PS3 are getting in the way.
UGOOS UT2/UM2 and UT1 official firmwaries
Noticed that "tchip remote control server" is trying to be accessed by my PS3 as a DLNA server and gets a 720 error from PS3. This is quite annoying when you're playing a game or movie on the PS3 and the error message keeps appearing on the PS3. Is this app for the factory remote control or for some kind of adaption for a PS3 joystick/game pad?
No way in the app manager to disable it but I did force stop it and the errors from the PS3 stopped until it started running on the UT2 again....this is a real problem as I have 2 UT2s and these error messages from PS3 are getting in the way.FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by Vinny1967 View PostInstalled firmware on my UT1 and it's working fine.Only thing that's annoying is the system bar at the bottom doesn't stay hidden after reboot.Is there a way to keep it hidden ?
Ava: Is there an ETA for the next version? Can someone confirm that USB On-the-Go is not working on this ROM? Where are the Mappings for the Remote located, so they can be extracted to use them with another ROM?Last edited by LX+R; 21 May 2015, 06:22.
ro.show.navigationbar=yes
qemu.hw.mainkeys=0
Originally posted by Vinny1967 View PostLast time I tried altering the build.prop I bricked my device :P .In the old firmware there was an option in the settings to hide the system bar.
I recently bought Ugoos UM2 with Android 4.2.2 on it. I downloaded firmware UM2_1.1.1_20150505.7z, renamed it as update.zip and tried to update firmware putting update.zip in a USB. When I go to Settings => About device, it detects that an update.zip file is found and do you want to install it. When I tap on install, it says that update file is not valid. I checked and firmware was downloaded properly. I tried unzipping it and then recreated ZIP file but it was all in vain. Please help. Thanks.
Originally posted by ksalman View PostI recently bought Ugoos UM2 with Android 4.2.2 on it. I downloaded firmware UM2_1.1.1_20150505.7z, renamed it as update.zip and tried to update firmware putting update.zip in a USB. When I go to Settings => About device, it detects that an update.zip file is found and do you want to install it. When I tap on install, it says that update file is not valid. I checked and firmware was downloaded properly. I tried unzipping it and then recreated ZIP file but it was all in vain. Please help. Thanks.
Why don't you use the normal method via recovery mode and the RKBatchTool: LINK
I tried that as well but my device was not detected (not connected or shown as green) in RKBatchTool even I had installed driver. I'm using Windows 7.
I tried pushing Reset button and then plugging in with my laptop through USB but nothing happens. Main issue is: UM2 is not being detected as an android device on my PC. No ideas. Please share if you got any clues or if I'm missing something. Thanks.Last edited by ksalman; 04 June 2015, 12:52.
Originally posted by ksalman View PostMain issue is: UM2 is not being detected as an android device on my PC. No ideas. Please share if you got any clues or if I'm missing something. Thanks.Last edited by LX+R; 05 June 2015, 17:45.
There are currently 3029 users online. 0 members and 3029 guests.
