UGOOS UT2/UM2 and UT1 official firmwaries
The WiFi on my UM2 works - it's just a shame it doesn't have an external antenna as the pick up rate isn't great, but with careful placement can get it to around -65dBm(my Nook HD+ in the same place gets -50dBm)
Have seen it possible to modify (http://omniapossibilia.blogspot.co.u...rovements.html) but not yet felt the need to tinker....
Is there an ETA for the next release? It has been over a month since the last "milestone". Despite the solution I found for bluetooth functionality on the UT1 I am not able to connect my Logitech K480 to the box, so the bluetooth issue is not completely solvedm although it is crucial for my use.
Originally posted by flhthemi View PostI guess I'm going to show how dumb I am...why would anyone need/want screen rotation on a TV box or stick?
I don't know what for either. I think it would be best if you optimize the core features (like bluetooth and init.d support) before you add fancy features, only a minority will use.
Originally posted by LX+R View PostI don't know what for either. I think it would be best if you optimize the core features (like bluetooth and init.d support) before you add fancy features, only a minority will use.
Thanks for suggestion!=))
I just wanted you to know that I kind of solved the problem with the Logitech K480 by using another USB bluetooth dongle (LINK). The adapter is based on a different chipset (Broadcom BCM20702 instead of CSR8510). So the problem is neither the bluetooth stack nor the keyboard but rather the integrated driver.Last edited by LX+R; 10 August 2015, 21:00.
Hi guys,
new release available for user of freaktabs.
Changelog:
version 1.1.2 - 11/08/2015
Added:
1. Ability use external USB Ethernet card
2. Internal Samba server
3. Support Init.d
4. Support exfat
5. Switcher for turn on/off fireeasy support.
6. Google Chrome browser
7. Added menu for settings hardware keyboard
8. Support multi partitions on usb storage
9. Chaged logic work of "Sound Devices Manager":
- Added ability choose input device
- Added ability choose usb output device
- Added restore settings after reboot
Updated:
1.Kodi was updated to version 15.0
2.busybox
Removed:
1. Skype
2. Wifi Analyzer
3. Speed test
Official release will be some later. OTA updates will be available with official release.
Please if you find bugs let me know.
Download firmware you can here:
UT1 - link
UT2 - link
UM2 - link
There are currently 2077 users online. 0 members and 2077 guests.
