It is very semi-rooted but I was able to dump all blocks with ADB. So I have the ROM that came on the stick. I will compare it with the downloaded ROM from geekbuying and see if they are the same.
This ROM is a little more polished than the MK908. Also based on info I see so far, I am betting this ROM comes from a different software house than the MK908. So clearly Tronsmart has spent more time on this ROM than the MK908.
The good so far:
Quick Antutu run gives me 15,500 give or take.
Interesting however that GPU being a 400MP is not faster than the MK908.
I get 44 FPS 2D and 12 FPS with 3D. Same number roughly I get with the MK908.
So might be some improvements to come there.
This ROM is 4.2.2 and has what the MK908 is missing
1) Hide button on status bar
2) Power button on status bar
3) Volume on status bar but I don't consider that a feature.
The bad so far:
1) No accessibility options or settings which is odd...
Did they remove accessibility settings in 4.2.2? I forget now from other 4.2.2 ROMs?
2) Fonts are a little small in some dialogs. This can be easily fixed though.
3) The unit does seem to get warmer than the MK908. Not sure it's an issue though. I will run a bunch of back to back 3D tests and see what it gets up to.
4) Nothing else so far that I can see. I will be checking for xpad.ko and other goods soon.
Time to analyze ROM dumps now
