Tronsmart T428 status so far
Re: Tronsmart T428 status so far
Originally posted by Spotopolis View PostREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostA little oftopic, how you remove the stock heatsink in mk808?, I try to do that and it is impossible for me. Any trick?
Once off let it cool for 5 - 10 minutes and then clean the cpu/nand/memory with rubbing alcohol and a qutip to get the extra gunk off. I wasn't able to clean all of the thermal epoxy off but it was in a spot that didn't need a heatsink anyway.
EDIT: Ill take some pics tonight and show you if you still need help.TV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
Originally posted by Spotopolis View PostA few ways you can do it. You can use the 808 at high clock speeds to heat up and loosen the tape and then power off the unit and use a knife/flathead screwdriver and pry it off, or if you have a heat gun you could use that. I wouldn't recommend the heatgun because everything is so close together you don't wanna pull anything extra off.
EDIT: Ill take some pics tonight and show you if you still need help.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostThanks a lot, heat is the trickTV Stick: MK808 // Tronsmart T428
Kernel: Persus
Originally posted by Spotopolis View PostAre you just looking or are you putting on a better heatsink? If so, are you going to post pictures of what you have done?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostI am going to try put a better one, I have some heatsinks here and I want to try them,TV Stick: MK808 // Tronsmart T428
Kernel: Persus
Originally posted by Spotopolis View PostAny update on photos? I may end up doing the same as my 808 and replace the heatsink with thermal paste and a NorthBridge heatsink. It depends on what you have on there.
You can remove that, and change to whatever you need.Looking for developers
Originally posted by geekbuying View Postphotos is coming, factory put the heatsink on CPU, memory, and other place, check the photo
You can remove that, and change to whatever you need.TV Stick: MK808 // Tronsmart T428
Kernel: Persus
Originally posted by leolas View PostI am going to try put a better one, I have some heatsinks here and I want to try them,FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
Originally posted by PoisonWolf View PostThat has got to be the cheap east heatsink I've ever seen in my life. Christ.TV Stick: MK808 // Tronsmart T428
Kernel: Persus
actually, the material for the heatsink is nanometre, i have asked factory today, this material is better the regular ones you see in market, and also it cost more than others.
factory tell us the heat on T428 is not a problem, each device which release from factory will have long time testing, and the temperature is all acceptable.
Originally posted by PoisonWolf View PostThat has got to be the cheap east heatsink I've ever seen in my life. Christ.Looking for developers
Originally posted by geekbuying View Postactually, the material for the heatsink is nanometre, i have asked factory today, this material is better the regular ones you see in market, and also it cost more than others.
The effectiveness of a heatsink is not based entirely on the material. Sure, the material affects the rate of heat conduction, but what affects the rate of heat dissipation is the surface area. Just sticking a plop of metal on the chip is silly. Why do you think CPU heatsinks have so many bends, curves, fins, etc? It is all solely to increase the rate of heat dissipation. More surface area = faster cooling.
The factory will obviously tell you that it is not a problem. Look at the MK808's heatsink vs this heatsink. Who's trying to cut costs? To the average person who buys your products and doesn't know how to change the heatsink, I'm fairly certain this product will likely have potential heat issues like the first batch of MK808s before the large heatsink was put on.
I'm not personally attacking you or anythng, I just want to make it clear that the factory's words isn't God's words or anything. My point still stands, that is one cheap-ass heatsink. I'll wait out the first batch to let other people be the first adopters for this one. I'm not convinced that the heatsink will do a thorough job.
Perhaps they were refering to the thermal paste.
Do you have a link?
Do you have a link?
I do like that it sounds like thermal paste rather than thermal epoxy though. Much easier to clean off and replace!TV Stick: MK808 // Tronsmart T428
Kernel: Persus
There are currently 4365 users online. 2 members and 4363 guests.
