edit: ok found method thank's leolas :-) thank you again to all :-)
DOWNLOAD AVAILABLE snakerom UG007 II based on a finless imito mx1/2 1.7a rom
ops, thank you. it's difficult to convert kernel.img in .zip format for clockworkmod recovery (just to try and test different kernel)? thank you again
edit: ok found method thank's leolas :-) thank you again to all :-)Last edited by hitman72; 07 May 2013, 18:17.Io ho 41 anni. Ho fatto tante cose, tante cose. Cose... cose di ogni genere. E una verità l'ho scoperta. Una sola verità. Sì una sola. Vuoi sapere qual'è? Ho scoperto che sono un porco bastardo. (tokyo decadence)
Finally got around to flashing this to my UG007-II.
Really like the looks, gives it a more modern feel.
Not sure if i notice anything about the performance scripts, it's very fast and responsive (with 1080p overclock kernel) but so was the Finless MX1/2 ROM.
Haven't noticed any problems so far. Great work!- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
- MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
- MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
Originally posted by 3r1s0n View Posthi. who tell me how i can connect my UG007 II to pc to flash this FW?
inside the folder you have a read me file .
follow this for installing the drivers.if you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
But i need to know one thing. I try to conn
ect stick with my pc, but nothing . I try to use different cables (original from nokia and not original) pc doesnt see my stick.
added a skydrive link
</form>
Originally posted by snakekiller View Postin settings on the stick go to usb and tick , connect to pc
http://sdrv.ms/12Htrb9
To put the UG802 into flash mode the easy way:
1) Remove any SDcard you may have installed.
2) Connected the supplied USB cable from the device OTG port to your PC.
It will power up and windows may detect the device. DO not worry about that. We need it powered up.
3) In the ROM kit run the ROM FLash Tool.exe.
4) You should see at the bottom it says "Found RKAndroid Mass Storage USB"
If it does not say that go into settings and make sure that
a) USB storage is turned ON
b) Under developer options, USB debugging is turned off
5) Once it says "Found RKAndroid Mass Storage Usb" in the flash tool click the "Reboot to Flash Mode" button.
6) Wait up to at least 10 seconds. The unit should reboot and the screen for the UG802 will be black (no ouptut).
7) If the unit does not reboot to a blank screen, repeats steps above
Congrats! You are now in flash mode! To get out of it at any time just unplug the USB power to the UG802.
It will boot back up normally out of flash mode.
If reboot to flash mode does not work, then use this alternate proceedure.
In my ROM kit is another folder called alternate_reboot_to_flash_tool
This is the RKBatch tool. Run this tool and the 1 box should be pink.
If it is not pink again make sure:
Once you have a pink box, Click the "switch" button at the bottom and this should put it into flash mode.
Close this RKBtach tool now.
4 step of this manual dont work for my stick.Last edited by 3r1s0n; 21 May 2013, 08:55.
if you love my tweaks on this rom .
i maked one with a rom from neomode too.
on neomodes rom is the mac adress good (name instead of 0000000000000)
i just uploaded a new update with more tweaks en ui mods.
here is the link to the topic
</form>
someone reported a blurry netflix issue with this rom.
i said try the modded snakegen rom from neomode .
he reported back thats everything works perfect now .if you love my work please buy a coffee
</form>
There are currently 1976 users online. 1 members and 1975 guests.
