MK802III S Bluetooth New NEOTV Custom Rom 1.8
    AW: MK802III S Bluetooth New NEOTV Custom Rom 1.8
    I have a Original Mk802IIIS from w2comp for developing. I have never heard about a Bluetooth Problem before. But I will take a Deep Look inside. Possible is that's a Module I deliver in this Rom not Running OK with the Mediatek Driver in the Kernel.
    Neomode Freaktab.com Developer
      But snakekiller also had a problem with Finless MX1/2 1.7 while that one worked fine for me.
      So yeah it would be nice if you can get it to work for him, but it might not have anything to do with your ROM.
      - UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
      - MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
      - MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
        there are several editions off this stick.
        you have the ug007 also with bluetooth but with one micro usb also.
        then the normal ug007 without bluetooth.
        then the ug007II with bluetooth and 2 micro usb
        there must be a different with my stick.
        it worked with the original rom. because i had the icon on the taskbar when i activated.
        if you love my work please buy a coffee
        <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
        </form>
          I also have an UG007-II, i'll let you know later today if it works for me.[/QUOTE]
          ok can't wait.
          this are the spec for the ug007B :Wifi-802.11 b/g/n (MediaTek 5931 in CDT-K25931 module)
          Bluetooth 3.0 (MediaTek 6622 in CDT-K25931 module)
          </form>
            Neomode did you solve the problem of wifi showing 00:00:00:00 instead of sid name ?
            How is the device identified in play store as Gt-I9100 or Rikomagic MK802IIIS ?
              the wifi is fixed
              and its gt-i9100
              </form>
                i must say that i must use the BT adapter for my flymouse to use it .
                also with stockrom. even if bluetooth was turned on.
                or is that normal that a flymouse only works with the adapter plugged in on the stick?
                </form>
                  are you sure that you flymouse is a bt one usually flymouse like MeleF10 and measy RC11-12-13 require their receiver because aren't BT but use 2,4 Ghz frequency
                    ahhhhh ok its a measy RC11
                    sow its normal then.
                    </form>
                      Hello all,
                      Here is my new Firmware for the MK802III S Bluetooth.
                      I have Rework the hole Rom, for Speed & Stability.
                      Feature:
                      - Fix Wlan showing Wlan Name not 0000000
                      Neomode
                      Originally posted by snakekiller View Post
                      the wifi is all zeros and its gt-i9100
                      So it's not fixed? (not that i care much BTW as long as WIFI works)
                        The new Rom 1.8 is fixed from the WLan Bug.
                          I notice that superuser is not saving root accept. Anyone notice that?
                            I have the firmware for the new PCB Version. I will be beginning to work with it.
                              what is PCB Version?
                              </form>
                                This is the new Layout of the Mainboard.
