MK802III S Bluetooth New NEOTV Custom Rom 1.8
    I had trouble with version 1.0 of this rom causing visual glitches on my MK802IIIS. I am now running Finless 1.7a with no problems. Is there any reason to switch to this rom?
      Thanks Neomode for all your hard work. Currently running 1.7 on my MK802IIIs and I'm absolutely loving it! No issues whatsoever. I'm very excited to upgrade to 1.8.
        Autohide statusbar would have been nice though
          Hi neomode, I've been using my 802 IIIS for 2 weeks, and I was not very satisfied with it.
          After reading a lot on this forums and on XDA, yesterday downloaded your rom 1.7, just about when I was ready to flash it, I found this new version...
          I'm downloading this rom right now, the only question I have is should I go with the new version as my first flash on the device?
          Thanks in advance for your hard work!
            Okay so I have played around with this rom for a while, I was coming from Finless 1.7a. It seems pretty good, although Finless 1.7a seemed a bit more responsive. Also it appears to be very laggy with my Sainsonic fly mouse/keyboard. The cursor stops and lags most of the time. I experienced it sometimes with the Finless 1.7a under load, but it happends all the time now :/
            Would have loved to keep this rom for the updated Stagefright though, but the cursorlag is killing me
              AW: MK802III S Bluetooth New NEOTV Custom Rom 1.8
              Hello surprised to me I have a Brand New Stock Firmware for the mk802IIIS.
              It is from 04/2013.
              I will make after a few Test a Custom Rom of it.
              Neomode
              Neomode Freaktab.com Developer
                It is from 04/2013.
                Neomode
                i flashed the stock already and again no BT
                if you love my work please buy a coffee
                <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
                </form>
                  We will see. Let me take a look on this new Firmware.
                    Hi Neomode, did you get my PM with firmware link?
                      Yes thanks Bro.
                      I have Test the Firmware and can say it is a good one. A new Kernel CPU running at 1.4 GHz and the GPU is Faster.
                      I will make a Custom Rom with it.
                        Yes thanks Bro.
                        Awesome, I can't wait to try it out. Hopefully the Wifi doesn't cut out either.
                          Neomode,
                          Would you mind sharing how you fixed the Wlan showing 0000000 instead of the name? I'm running Finless 1.7a on my UG008 with the stock UG008 kernel and it is doing this.
                          I'm also looking forward to trying your rom based on the new mk802IIIs firmware when it is ready.
                          Thanks,
                          Tony
                            from CWM?
                            Hi Neomode.
                            Sometime ago I broke the USB plug where to execute the flash tool in download mode. Now, is there any possibility to flash the ROM from CWM (I installed the 6 version)? I mean, provided that there's no way to flash it from the HOST USB port (?) and the AC port.
                            Thank you
                              To be honest i haven't tested it much, but this ROM seems to crash my UG007(II) every now and then. Not under stress or anything but just while it's sitting there. On the other hand it does seem to use a lot less power! (which might cause the crashes if it's just undervolting too much). Often when it's idle my powermeter doesn't even report anything?! (Which i guess would mean less or at least around just 1w)
                              Another funny thing is it wont connect to my wifi router. I have a pretty weak signal so it wont connect with the message "Avoided poo internet connection" Which i think is very helpfull, avoiding a poor connection to leave me without any.
                              Was going to try with my USB WIFI dongle, but since there is a new stock ROM with new kernel i'll wait for that one. The faster GPU sounds great. Will probably be enough to play full 1920x1080 movies using XBMC (on a 720p kernel which i guess it is right?)
                              EDIT: Just tested a few video files from SD-card and they seem to run quite bad. Even 1920x800 had a lot of dropped frames.
                              - UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
                              - MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
                              - MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
                                Originally posted by danifeb View Post
                                Hi Neomode.
                                Thank you
                                His ROM is split up in seperate .img files, so i guess updating through CWM should work just fine if you use the right zip file structure and other needed files.
