ro.sys.hiritsu is no longer in the last Roms. I tried to reintroduce it, but no significant effect. I remember that all 30 tests Antutu Video were successful with early versions. With this latest rom, just 19! Can you help me: What have I to change exactly in the build prop to reintegrate correctly ro.sys.hiritsu? I am convinced that we do not use the full potential of our box! Thanks. (I am using Draco Telos)
[ROM] "Finally v0.1" based on MK80_SDK3.0_150627 (thanks to Boxx!!!)
I make an hypothesis: if the proposed first Roms were not so bad as that!
Originally posted by kacim View PostI use GJayJayG ROM.. it's fine, but I noticed that navbar doesn't work ..
It comes with a replacement for the integrated navbar for a good reason. Launch the app "udn lite" and configure it to your needs. Navbar will be on the right side now.
Originally posted by npoupine View PostI make an hypothesis: if the proposed first Roms were not so bad as that!
I spent 6 hours to test 3 roms based on SDK3 Tronsmart, Boxx and JJ.
The purpose of my Draco is for video streaming from internet.
All video streaming apps work fine with all 3 roms.
BUT when i stream video with browsers (chrome, dolphin, Firefox, opera), i see the difference: JJ rom may crash.
The best rom for MY USAGE is BOXX rom.
So if Boxx wants to improve your rom, please use your original rom.
The same browser does not behave with the same manner on the same website, between SDK2 and SDK3.
If I use chrome on website A under SDK2, I might change to firefox on website A under SDK3.
Originally posted by npoupine View PostHiritsu adds a multiplier for the real antutu score. I know that, I am ok. But about all test pass in "video Antutu test", isn't it strange?
I just ran it on the MK80_SDK3.0_150627 firmware with and without hiritsu.
Just one 4k video failed everything else is fine.
So if you have a bad result there, it is probably because of the tweaks in GJays rom.
I'm sorry if I'm completely stupid and am missing something here but why do some apps crash google play services? Can the framework not handle them? I've been looking into this for well over a month now and I can't find any other people having the same issue as I am. I am using an instabox fantasy, which as far as I can tell is identical to your guy's box. It happens with tincore's keymapper that I use, there are others but I don't care about them. Anyone have any thoughts on this. Thanks boxx and gjay
Sent from my LG-H812 using Tapatalk
Originally posted by Moulin1980Hi, I found a problem, with web videos.
When I watch the video, full screen mode, the video stop.
Example with the site " http://www.mystere-tv.com/ ".
Sent from my K013 using Tapatalk
I can NOT play any video under Boxx or JJ rom with any browser:chrome,dolphin, opera, stock... The ONLY BROWSER that can play is firefox .
Under sdk2, that works perfectly with chrome ! Could you help, Boxx or JJ? THANKS
Hi frhdt007, I found a solution with the "browser dolphin", for :
For the ROM "Finally v0.1", I just only , customize the ROM, to retrieve the navbar and delete Ultimate Dynamic Navbar.
In BUILDPROP, i just modified :
qemu.hw.mainkeys=0
I use a lot of Navbar.
There are currently 2058 users online. 1 members and 2057 guests.
