Tronsmart T428 thermal problem
Originally posted by geekbuying View PostTV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
Originally posted by geekbuying View PostHi guys:
After last time we talked about the heatsink, i have contacted the factory immediately and push them to change that, now the t428 has all shipped with aluminum heatsink....
The heatsink itself is not there problem.
Place the board in a case and you'll see that he is still useable hot.
The problem is that can not be discharged the heat to the outside.
I post my, hope finally successful, action next week.
I have to wait for my ordered parts.
Originally posted by Spotopolis View PostIt would also be nice to receive another update on my shipping info. last bit of info I got was it left the dispatch center on 4-25... that was over two weeks ago and I haven't gotten a single update since then.
do not trust the tracking service.
my status:
QUOTE
The shipment has arrived in the destination country
END QUOTE
but my stick is already here
The rk3066 device temperature is max 85C.
RK3066 datasheet. http://www.giayee.com/uploadfile/201...6054130906.pdf
42. page Operating temperature min. -40C max. 85C
If the RK3188 device temperature is 52C then no problem.
But need a heatskin.
Thanks for the information.
Read my first contribution, at a outsidetemperature of 53.8 crashes the stick.
I could not measure how high the temperature was internally.
After last time we talked about the heatsink, i have contacted the factory immediately and push them to change that, now the t428 has all shipped with aluminum heatsink, check the following photos:
Only a very few pcs at first will have s0s ones heatsink, if you really have the heat problem, please make sure to contact our customer service, and they will offer you some solution.
Geekbuying
That's better than nothing.
A good heat sink is how it works, see the picture:
Sorry not see.Then is big problem.
My RK3066 device temperature is 55C if playing game and work.
news from the front
on the bottom of the sticks fits really a cool body.
It can be up to 1mm thick
I'm not finished yet but I have to test.
The heat sink has to Antuto 39.8°C
From Monday you continue.
processorside and case with cutout (not perfect but ....)
CPU and memory Heat Sink
side
in housing
Very clever and looking good. Thank you for sharing !
Just a heads-up to everyone.
Be careful and do not click on any of many popup ads where these images
are hosted. Some come up as fake (legit looking) FLASH UPDATE pages and will install
a bunch of junk instantly on your PC if you click on them.
(Happened to my friend who is not that computer savvy and who told me about this thread)
side
in housing
If you have a problem, do part of a ventilation system.
http://www.****.com/itm/25mm-Small-F...item35bff762a6
good to know.
I still do not need a fan, I have several times AnTuTu and the
stability test run, everything without problems or crash.
To the underside still needs a heatsink glued and i think then it's perfect.
There are currently 2123 users online. 0 members and 2123 guests.
