Format s82
Originally posted by deecee View PostI have tried the toothpick method ....although I may have done it incorrectly. I grabbed the exact same firmware and put it on a micro SD then engaged the toothpick button. It seems to install 100 percent, but then just hangs there. I've left it for hours. Didn't seem to work.
param
recovery
rom
then you press together the power and the reset and didn't release them until you see android flashing the firmware?
If you did all this then you might have to try a different firmware like iysp suggest it i am 95% that if it's a software problem this
is the way to resolve it and it will.
Best of luck to you.
Edit: Tells us the exact model,brand, that you have.
Originally posted by aeolous View Postyou put the 3 files to microsd right?
param
recovery
rom
If toothpick-methode don't work, try to flash new firmware over otg-port.
Download the aml_USB_burning_Tool and some s82/s802/k200-ota-firmware-rom (not TF-/SD-card file) and burn from PC. Then you can use again sd-card method to flash firmware you want.
Originally posted by bergl View PostIf toothpick-methode don't work, try to flash new firmware over otg-port.
There are currently 3089 users online. 0 members and 3089 guests.
