This is my custom Rom for the Tronsmart R68, enjoy another alternative
What's inside :
Beta 1
- Built from source. This is a userdebug build.
- Unified Storage
- TWRP 2.8.7.0, it will be installed after first boot
- ADB shell as root
- Rooted with SuperSU
- init.d support, it will also run a script from inside data/local/userinit folder or just data/local/userinit.sh
- Some apps installed as user, including kodi 15.1 rc1.
I also cleaned,updated and fix some things compared Stock image
How to install
- Power off your R68
- Grab a paper clip insert in the reset hole in back. Press and hold the reset button now press power button. Your R68 should appear as loader device.
- Choose your image(s), press upgrade or run.
I have uploaded some tools if you need them
DOWNLOAD
- www.freak-tab.de/abdul_pt/r68/R68_Beta1.zip
- md5 checksum - 7e29c18c60f0f34e7a934ef1dae6cadc
